跳转到主内容
加入维修社区 - 创建账户
Alienware M17x Display Assembly Replacement
你所需要的
    1. Alienware M17x Display Assembly Replacement, Battery: 步骤 1 中的图像 1,2 Alienware M17x Display Assembly Replacement, Battery: 步骤 1 中的图像 2,2
      • Turn off your laptop before starting.
      • Flip the laptop over so the model stickers face the ceiling.
      询问修复机器人
      添加评论
    2. Alienware M17x Display Assembly Replacement: 步骤 2 中的图像 1,1
      • Remove the two 3.5 mm Phillips #0 screws holding the cover in place.
      • Slide cover forward then carefully lift up.
      询问修复机器人
      添加评论
    3. Alienware M17x Display Assembly Replacement: 步骤 3 中的图像 1,1
      • Remove the two 5.5 mm Phillips #0 screws holding the battery in place.
      询问修复机器人
      添加评论
    4. Alienware M17x Display Assembly Replacement: 步骤 4 中的图像 1,2 Alienware M17x Display Assembly Replacement: 步骤 4 中的图像 2,2
      • Carefully use the Plastic Opening Tool to unplug the battery.
      • Lift the battery up and out to remove.
      询问修复机器人
      添加评论
    1. Alienware M17x Display Assembly Replacement, Display Assembly: 步骤 5 中的图像 1,1
      • Flip the laptop back over so that the Alienware logo faces the ceiling then open the lid to view the screen.
      询问修复机器人
      添加评论
    2. Alienware M17x Display Assembly Replacement: 步骤 6 中的图像 1,3 Alienware M17x Display Assembly Replacement: 步骤 6 中的图像 2,3 Alienware M17x Display Assembly Replacement: 步骤 6 中的图像 3,3
      • Use a spudger as a lever to pry the black plastic siding off of the frame starting on either of the top corners.
      • Use the spudger to remove the siding from the bottom of the frame near the hinges.
      • Carefully lift the black plastic siding up and out of the hinged area making sure not to break the fragile sides.
      询问修复机器人
      添加评论
    3. Alienware M17x Display Assembly Replacement: 步骤 7 中的图像 1,2 Alienware M17x Display Assembly Replacement: 步骤 7 中的图像 2,2
      • Use the plastic opening tool to disconnect the screen from the top mount.
      询问修复机器人
      添加评论
    4. Alienware M17x Display Assembly Replacement: 步骤 8 中的图像 1,1
      • Avoid directly touching the connectors with anything other than plastic tools to avoid damaging the internal components.
      询问修复机器人
      添加评论
    5. Alienware M17x Display Assembly Replacement: 步骤 9 中的图像 1,1
      • Tilt the screen forward to expose the connecting wires.
      • Disconnect said wires to then lift the display assembly out of the frame.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 32
总计 1,032
