跳转到主内容
加入维修社区 - 创建账户
Alienware M17-R1 Screen Lock Assembly Replacement
你所需要的
    1. Alienware M17-R1 Screen Lock Assembly Replacement, Screen Lock Assembly: 步骤 1 中的图像 1,1
      • Open the screen until it is flat.
      • Ensure that the surface you are working on can support both the screen and the base of the laptop.
      询问修复机器人
      添加评论
    2. Alienware M17-R1 Screen Lock Assembly Replacement: 步骤 2 中的图像 1,2 Alienware M17-R1 Screen Lock Assembly Replacement: 步骤 2 中的图像 2,2
      • Remove the eight 7 mm screws around the edge of the screen using a Phillips #1 screwdriver.
      • Support the screen from the bottom to make it easier to remove the screws.
      询问修复机器人
      添加评论
    3. Alienware M17-R1 Screen Lock Assembly Replacement: 步骤 3 中的图像 1,2 Alienware M17-R1 Screen Lock Assembly Replacement: 步骤 3 中的图像 2,2
      • Insert the plastic opening tool and gently slide it around the edge of the screen to lift the face of the screen away from its base.
      • Be careful not to break the face of the screen when lifting it.
      询问修复机器人
      添加评论
    4. Alienware M17-R1 Screen Lock Assembly Replacement: 步骤 4 中的图像 1,3 Alienware M17-R1 Screen Lock Assembly Replacement: 步骤 4 中的图像 2,3 Alienware M17-R1 Screen Lock Assembly Replacement: 步骤 4 中的图像 3,3
      • Remove the two 3 mm Phillips #1 screws using a Phillips #1 screwdriver.
      • Pull the assembly grip away to remove it.
      • Remove the two 5 mm screws using a Phillips #1 screwdriver.
      询问修复机器人
      添加评论
    5. Alienware M17-R1 Screen Lock Assembly Replacement: 步骤 5 中的图像 1,2 Alienware M17-R1 Screen Lock Assembly Replacement: 步骤 5 中的图像 2,2
      • Push in the assembly towards the spring.
      • Gently lift the slider from the side opposite to the spring and pull the slider away from the spring.
      • The spring is loosely secured to the slider and may fall off and become lost when removing the slider.
      询问修复机器人
      添加评论
    6. Alienware M17-R1 Screen Lock Assembly Replacement: 步骤 6 中的图像 1,2 Alienware M17-R1 Screen Lock Assembly Replacement: 步骤 6 中的图像 2,2
      • If the spring is defective, slide it off the end of the assembly and replace it.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
William Davis
于10/09/18注册
323 声望
创作了2篇指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 42
总计 748
