简介
This guide will show you how to safely access and replace the RAM sticks for the Alienware M14xR2 laptop. In order to remove the RAM you need to first remove the battery and the CD drive.
你所需要的
Turn the computer off.
Disconnect the charging cable from the computer.
Flip the computer upside down.
Unscrew the four 6.35 mm size 1 screws.
Pull up on the end of the orange tab to detach it from the white connector.
Lift the optical drive up and out of the laptop and set it aside.
4等其他人完成本指南。
3指南评论
How max is the ram upgrade compatible with the m14x ifixit?!
doantuan85 - 回复 分享
I meaned r1 model
doantuan85 - 回复 分享
