跳转到主内容
加入维修社区 - 创建账户
Alienware 17 R4 Battery Replacement
你所需要的
    1. Alienware 17 R4 Battery Replacement, Base Cover: 步骤 1 中的图像 1,1
      • Use a PH1 screwdriver bit to remove the six M2.5x13 screws (2.4 mm) on the back of the laptop.
      • Use a PH1 screwdriver bit to loosen the one M2x3 screw (1.9 mm).
      • The M2x3 screw (1.9 mm) does not come out completely.
      询问修复机器人
      添加评论
    2. Alienware 17 R4 Battery Replacement: 步骤 2 中的图像 1,2 Alienware 17 R4 Battery Replacement: 步骤 2 中的图像 2,2
      • Pull the base cover up to remove it.
      • If you are having trouble, insert a plastic opening tool into the divots along the laptop's edges to loosen.
      • Removing the cover may require some force.
      添加评论
    1. Alienware 17 R4 Battery Replacement, Hard Disk Drive (HDD): 步骤 3 中的图像 1,3 Alienware 17 R4 Battery Replacement, Hard Disk Drive (HDD): 步骤 3 中的图像 2,3 Alienware 17 R4 Battery Replacement, Hard Disk Drive (HDD): 步骤 3 中的图像 3,3
      • Disconnect the battery connector cable, located on the right side of the laptop, above the hard disk drive.
      • Once you have removed the cable, wait 5-10 minutes to allow the laptop to power down.
      • Failure to remove the battery connector cable properly may damage other parts of the laptop.
      询问修复机器人
      添加评论
    2. Alienware 17 R4 Battery Replacement: 步骤 4 中的图像 1,3 Alienware 17 R4 Battery Replacement: 步骤 4 中的图像 2,3 Alienware 17 R4 Battery Replacement: 步骤 4 中的图像 3,3
      • Use a PH1 screwdriver bit to remove the four M2.5x5 screws (2.4 mm) on the hard disk drive.
      询问修复机器人
      添加评论
    3. Alienware 17 R4 Battery Replacement: 步骤 5 中的图像 1,3 Alienware 17 R4 Battery Replacement: 步骤 5 中的图像 2,3 Alienware 17 R4 Battery Replacement: 步骤 5 中的图像 3,3
      • Gently lift the HDD cable to disconnect it from the laptop.
      询问修复机器人
      添加评论
    4. Alienware 17 R4 Battery Replacement: 步骤 6 中的图像 1,2 Alienware 17 R4 Battery Replacement: 步骤 6 中的图像 2,2
      • Pull the hard drive up to remove.
      询问修复机器人
      添加评论
    1. Alienware 17 R4 Battery Replacement, RAM: 步骤 7 中的图像 1,3 Alienware 17 R4 Battery Replacement, RAM: 步骤 7 中的图像 2,3 Alienware 17 R4 Battery Replacement, RAM: 步骤 7 中的图像 3,3
      • Move the metal sidings outward to release the RAM card.
      询问修复机器人
      添加评论
    2. Alienware 17 R4 Battery Replacement: 步骤 8 中的图像 1,1
      • Slide the RAM card out towards yourself to remove it.
      • Repeat the same step for the RAM card above.
      • Slide the RAM card out carefully to avoid damaging it.
      询问修复机器人
      添加评论
    1. Alienware 17 R4 Battery Replacement, Wi-Fi card: 步骤 9 中的图像 1,1
      • Locate the WI-FI card.
      询问修复机器人
      添加评论
    2. Alienware 17 R4 Battery Replacement: 步骤 10 中的图像 1,2 Alienware 17 R4 Battery Replacement: 步骤 10 中的图像 2,2
      • Peel back plastic cover of wi-fi card.
      • Use a PH1 screwdriver bit and remove the one M2x3 screw (1.9 mm)
      询问修复机器人
      添加评论
    3. Alienware 17 R4 Battery Replacement: 步骤 11 中的图像 1,3 Alienware 17 R4 Battery Replacement: 步骤 11 中的图像 2,3 Alienware 17 R4 Battery Replacement: 步骤 11 中的图像 3,3
      • Gently undo the clips attached to the wi-fi card.
      • If the clip is not gently removed it is possible that the entire base will be torn off the wi-fi card. You will need to purchase a new wi-fi card if this occurs.
      询问修复机器人
      添加评论
    4. Alienware 17 R4 Battery Replacement: 步骤 12 中的图像 1,2 Alienware 17 R4 Battery Replacement: 步骤 12 中的图像 2,2
      • Locate the cables that connect the wi-fi card.
      • Gently pull upwards to remove cables and slide the wi-fi card out from its slot.
      添加评论
    1. Alienware 17 R4 Battery Replacement, Solid State Drive: 步骤 13 中的图像 1,2 Alienware 17 R4 Battery Replacement, Solid State Drive: 步骤 13 中的图像 2,2
      • Remove the one M2x3 screw (1.9 mm) using a PH1 screwdriver bit
      询问修复机器人
      添加评论
    2. Alienware 17 R4 Battery Replacement: 步骤 14 中的图像 1,2 Alienware 17 R4 Battery Replacement: 步骤 14 中的图像 2,2
      • Slide the solid state drive towards yourself to prevent damage to the card.
      添加评论
    1. Alienware 17 R4 Battery Replacement, Fan Shroud: 步骤 15 中的图像 1,3 Alienware 17 R4 Battery Replacement, Fan Shroud: 步骤 15 中的图像 2,3 Alienware 17 R4 Battery Replacement, Fan Shroud: 步骤 15 中的图像 3,3
      • Remove the two M2.5x7 screws (2.44 mm) located on the rear panel using a PH1 screwdriver bit.
      询问修复机器人
      添加评论
    2. Alienware 17 R4 Battery Replacement: 步骤 16 中的图像 1,2 Alienware 17 R4 Battery Replacement: 步骤 16 中的图像 2,2
      • Insert the plastic opening tool under the fan shroud to slowly lift it up.
      • Repeat process on the middle and opposite side.
      询问修复机器人
      添加评论
    3. Alienware 17 R4 Battery Replacement: 步骤 17 中的图像 1,2 Alienware 17 R4 Battery Replacement: 步骤 17 中的图像 2,2
      • Firmly lift the plastic opening tool and pull the fan shroud towards you.
      • This will take a large amount of force and will not come out easily the first time.
      • Careful not to tear out the piece causing damage to the fan shroud
      询问修复机器人
      添加评论
    1. Alienware 17 R4 Battery Replacement, Plastic Cover: 步骤 18 中的图像 1,3 Alienware 17 R4 Battery Replacement, Plastic Cover: 步骤 18 中的图像 2,3 Alienware 17 R4 Battery Replacement, Plastic Cover: 步骤 18 中的图像 3,3
      • Unscrew the two M2x3 screws (1.9 mm) at the top right and top left of the laptop that hold the tron lights in place.
      询问修复机器人
      添加评论
    2. Alienware 17 R4 Battery Replacement: 步骤 19 中的图像 1,2 Alienware 17 R4 Battery Replacement: 步骤 19 中的图像 2,2
      • Follow the wiring to unplug the tron lights.
      添加评论
    3. Alienware 17 R4 Battery Replacement: 步骤 20 中的图像 1,3 Alienware 17 R4 Battery Replacement: 步骤 20 中的图像 2,3 Alienware 17 R4 Battery Replacement: 步骤 20 中的图像 3,3
      • Remove the fourteen M2.5XL8' screws (2.4 mm) located in the plastic cover using the PH1 screwdriver.
      添加评论
    4. Alienware 17 R4 Battery Replacement: 步骤 21 中的图像 1,1
      • Use the plastic opening tool to gently lift the sides of the cover.
      询问修复机器人
      添加评论
    5. Alienware 17 R4 Battery Replacement: 步骤 22 中的图像 1,2 Alienware 17 R4 Battery Replacement: 步骤 22 中的图像 2,2
      • Slowly lift up the plastic cover.
      添加评论
    1. Alienware 17 R4 Battery Replacement, Battery: 步骤 23 中的图像 1,3 Alienware 17 R4 Battery Replacement, Battery: 步骤 23 中的图像 2,3 Alienware 17 R4 Battery Replacement, Battery: 步骤 23 中的图像 3,3
      • Unscrew the four M2.5 screws (2.4 mm) with a PH1 screwdriver bit.
      询问修复机器人
      添加评论
    2. Alienware 17 R4 Battery Replacement: 步骤 24 中的图像 1,2 Alienware 17 R4 Battery Replacement: 步骤 24 中的图像 2,2
      • Lift the battery up to remove it.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
32等其他人完成本指南。
团队
CSU Fullerton, Team S2-G4, Bruce Fall 2017 CSU Fullerton, Team S2-G4, Bruce Fall 2017 的会员
CSUF-BRUCE-F17S2G4
4 名成员
创作了27篇指南
9指南评论
Very good guide, just one error, step 11 comes first then step 10. You can't lift the card before remove the screw.
alex.afnet - 回复 分享
Great guide, no issues at all!
Glenn Bell - 回复 分享
First time I've cracked opened up a computer in decades. This step by step guide gave me the confidence I needed! Thank you so much. It took me longer, about two hours with stopping to label screws and things but everything is up and running again. I'm so happy!
Michelle - 回复 分享
I would not recommend disconnecting the wifi card. the connectors are tiny. if you screw up, best case you need a new wifi card, worst case you are going to need to replace the antenna, and that isn’t fun.
John Wohlwend - 回复 分享
After the battery replacement? do we need to do anything else for calibration so that the Alienware knows that it is a fresh battery and battery cycle ... as i have heard that you need to repeat 3X the process of discharging and charging for calibration. or can we just plug and play? I am getting a new battery for mine soon. Thanks =)
Yannick Docq - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 44
过去 30 天: 249
总计 39,678
