跳转到主内容
加入维修社区 - 创建账户
Alcatel OneTouch Pop Icon Control Buttons Replacement
你所需要的
    1. Alcatel OneTouch Pop Icon Control Buttons Replacement, Battery: 步骤 1 中的图像 1,1
      • Shut down the device
      • Flip the phone so that the screen is facing the surface you are working on
      • Aggressive prying may result in damaging the back panel or the internal contents of the phone.
      • Use the plastic opening tool to gently pry off the back panel. There is a small notch in the bottom left corner of the phone that you can use for increased leverage.
      询问修复机器人
      添加评论
    2. Alcatel OneTouch Pop Icon Control Buttons Replacement: 步骤 2 中的图像 1,2 Alcatel OneTouch Pop Icon Control Buttons Replacement: 步骤 2 中的图像 2,2
      • Use your thumbnail to lift the battery from the phone.
      询问修复机器人
      添加评论
    1. Alcatel OneTouch Pop Icon Control Buttons Replacement, Interior Back Panel: 步骤 3 中的图像 1,1
      • Using the J000 Phillips screwdriver, remove the twelve silver 3mm screws.
      • Using the J000 Phillips screwdriver, remove the one green 3mm screw.
      询问修复机器人
      添加评论
    2. Alcatel OneTouch Pop Icon Control Buttons Replacement: 步骤 4 中的图像 1,1
      • With the screen facing you and the front facing camera to your right, insert the plastic opening tool between the screen and the interior back panel and gently pry it off.
      • Make sure all of the clips come undone when you pry the seam loose.
      询问修复机器人
      添加评论
    1. Alcatel OneTouch Pop Icon Control Buttons Replacement, Control Buttons: 步骤 5 中的图像 1,1
      • Lift the latch and gently remove the ribbon from the latch.
      询问修复机器人
      添加评论
    2. Alcatel OneTouch Pop Icon Control Buttons Replacement: 步骤 6 中的图像 1,2 Alcatel OneTouch Pop Icon Control Buttons Replacement: 步骤 6 中的图像 2,2
      • Use the metal spudger to gently pry the control buttons from the case.
      • The control buttons are glued to the case and are on a computer ribbon. When removing them it is best to move between them so as to avoid damaging them.
      • Make sure to use a plastic opening tool or nylon spudger before attempting to use a metal spudger. Metal spudgers can potentially damage your device.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 22
总计 901
