跳转到主内容
加入维修社区 - 创建账户
Alcatel OneTouch Evolve Volume Control Button Replacement
你所需要的
    1. Alcatel OneTouch Evolve Volume Control Button Replacement, Locate the access tab: 步骤 1 中的图像 1,1
      • This will be an opening with enough space to insert the flat head of the plastic opening tool.
      • It will be located on the bottom right of the phone
      询问修复机器人
      添加评论
    2. Alcatel OneTouch Evolve Volume Control Button Replacement, Place the flat head end of the pry tool into the tab: 步骤 2 中的图像 1,3 Alcatel OneTouch Evolve Volume Control Button Replacement, Place the flat head end of the pry tool into the tab: 步骤 2 中的图像 2,3 Alcatel OneTouch Evolve Volume Control Button Replacement, Place the flat head end of the pry tool into the tab: 步骤 2 中的图像 3,3
      • Rotate the pry tool 90 degrees until the panel lifts up.
      • With your thumb nail, lift the rest of the panel up around the perimeter of the phone.
      询问修复机器人
      添加评论
    1. Alcatel OneTouch Evolve Volume Control Button Replacement, Identify the Battery: 步骤 3 中的图像 1,1
      • This is the battery for the Alcatel One Touch Evolve. Look for this component when the back panel has been removed.
      询问修复机器人
      添加评论
    2. Alcatel OneTouch Evolve Volume Control Button Replacement, Removing the battery: 步骤 4 中的图像 1,2 Alcatel OneTouch Evolve Volume Control Button Replacement, Removing the battery: 步骤 4 中的图像 2,2
      • Place finger in the tab on the top right corner of the battery indicated by a black arrow. With slight pressure, push battery down and out of the slot until the battery is removed
      询问修复机器人
      添加评论
    1. Alcatel OneTouch Evolve Volume Control Button Replacement, Locate Screws Holding the Secondary Panel in Place: 步骤 5 中的图像 1,1
      • There will be eight 4.5mm screws that fit your Phillips head PH00 screwdriver notated by the red circles in the image.
      询问修复机器人
      添加评论
    2. Alcatel OneTouch Evolve Volume Control Button Replacement, Remove Screws: 步骤 6 中的图像 1,1
      在这个步骤中使用的工具:
      • Unscrew each screw, counter-clockwise (left), until each one has been removed.
      • If necessary, use tweezers to fully remove the screws from the device.
      • Remove battery before lifting off the panel.
      询问修复机器人
      添加评论
    3. Alcatel OneTouch Evolve Volume Control Button Replacement, Prying the Panel Off: 步骤 7 中的图像 1,3 Alcatel OneTouch Evolve Volume Control Button Replacement, Prying the Panel Off: 步骤 7 中的图像 2,3 Alcatel OneTouch Evolve Volume Control Button Replacement, Prying the Panel Off: 步骤 7 中的图像 3,3
      • Access the small pry tool in the tool kit
      • Place flat head in the crease between the phone and panel where the matte finish meets the shiny finish of the front of the phone.
      • Rotate the pry tool 90 degrees until part of the panel lifts up
      • All areas need to be fully risen off before the panel can be removed.
      • Do not use the opening tool to pry open the device near the power button or near the volume button.
      询问修复机器人
      添加评论
    1. Alcatel OneTouch Evolve Volume Control Button Replacement, Locate Volume Control Button: 步骤 8 中的图像 1,1
      • This will be located in the top right of the back side of the secondary panel and will be clear in color.
      询问修复机器人
      添加评论
    2. Alcatel OneTouch Evolve Volume Control Button Replacement, Remove Volume Control Button: 步骤 9 中的图像 1,1
      在这个步骤中使用的工具:
      • Using the smaller pry tool, place the flat head on the area of the button exposed to the exterior, and push with slight pressure until the button is inside the secondary panel.
      • Using the tweezers, lift the clear rubber extensions of the volume buttons out of their tabs located inside the secondary panel.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
Brendan Egan
于10/28/14注册
2,491 声望
创作了5篇指南
团队
UMass Dartmouth, Team 4-5, Miles Fall 2014 UMass Dartmouth, Team 4-5, Miles Fall 2014 的会员
UMASSD-MILES-F14S4G5
3 名成员
创作了72篇指南
1指南评论
Thank so much for post/
Sonnerie France - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 7
过去 30 天: 27
总计 3,419
