跳转到主内容
加入维修社区 - 创建账户
Alcatel OneTouch Evolve Battery Removal
你所需要的
  1. Alcatel OneTouch Evolve Battery Removal, Locate the access tab: 步骤 1 中的图像 1,1
    • This will be an opening with enough space to insert the flat head of the plastic opening tool.
    • It will be located on the bottom right of the phone
    询问修复机器人
    添加评论
  2. Alcatel OneTouch Evolve Battery Removal, Place the flat head end of the pry tool into the tab: 步骤 2 中的图像 1,3 Alcatel OneTouch Evolve Battery Removal, Place the flat head end of the pry tool into the tab: 步骤 2 中的图像 2,3 Alcatel OneTouch Evolve Battery Removal, Place the flat head end of the pry tool into the tab: 步骤 2 中的图像 3,3
    • Rotate the pry tool 90 degrees until the panel lifts up.
    • With your thumb nail, lift the rest of the panel up around the perimeter of the phone.
    询问修复机器人
    添加评论
  3. Alcatel OneTouch Evolve Battery Removal, Identify the Battery: 步骤 3 中的图像 1,1
    • This is the battery for the Alcatel One Touch Evolve. Look for this component when the back panel has been removed.
    询问修复机器人
    添加评论
  4. Alcatel OneTouch Evolve Battery Removal, Removing the battery: 步骤 4 中的图像 1,2 Alcatel OneTouch Evolve Battery Removal, Removing the battery: 步骤 4 中的图像 2,2
    • Place finger in the tab on the top right corner of the battery indicated by a black arrow. With slight pressure, push battery down and out of the slot until the battery is removed
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
12等其他人完成本指南。
Brendan Egan
于10/28/14注册
2,491 声望
创作了5篇指南
团队
UMass Dartmouth, Team 4-5, Miles Fall 2014 UMass Dartmouth, Team 4-5, Miles Fall 2014 的会员
UMASSD-MILES-F14S4G5
3 名成员
创作了24篇指南
5指南评论
Thanks 4 the info.
dennisp1964 - 回复 分享
my phone is rooted
next time i,m delete all software
now my phone show only lock screen
how to install my old software
Noushad Marshi - 回复 分享
please replay
Thank you very much!
Kath B - 回复 分享
Easy and clear instructions! I am 95 yrs old and I found your instructions wonderful! Thank you Helen Spriggs
Helen Spriggs - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 41
总计 10,576
