跳转到主内容
加入维修社区 - 创建账户
Alcatel One Touch Pop 7 Rear Camera Replacement
你所需要的
  1. Alcatel One Touch Pop 7 Rear Camera Replacement, Volume Button Assembly: 步骤 1 中的图像 1,1
    • Begin working by using the plastic opening tool to remove the back cover of your Alcatel One Touch Pop 7. Opening the flap as shown in the picture will give you an easier start.
    询问修复机器人
    添加评论
  2. Alcatel One Touch Pop 7 Rear Camera Replacement: 步骤 2 中的图像 1,3 Alcatel One Touch Pop 7 Rear Camera Replacement: 步骤 2 中的图像 2,3 Alcatel One Touch Pop 7 Rear Camera Replacement: 步骤 2 中的图像 3,3
    在这个步骤中使用的工具:
    • With the back cover removed you will now want to disconnect the battery. Use the tweezers and gently pull the wires as shown in the second picture.
    询问修复机器人
    添加评论
  3. Alcatel One Touch Pop 7 Rear Camera Replacement: 步骤 3 中的图像 1,2 Alcatel One Touch Pop 7 Rear Camera Replacement: 步骤 3 中的图像 2,2
    • The volume button assembly is in the top left corner of the tablet. To begin, you will have to pull the small black tab of the ZIF connector, shown in the second picture, to be able to remove the assembly. The tab is on a hinge so it should not be pulled off completely.
    询问修复机器人
    添加评论
  4. Alcatel One Touch Pop 7 Rear Camera Replacement: 步骤 4 中的图像 1,3 Alcatel One Touch Pop 7 Rear Camera Replacement: 步骤 4 中的图像 2,3 Alcatel One Touch Pop 7 Rear Camera Replacement: 步骤 4 中的图像 3,3
    • Pull the copper ribbon cable from the tab. It should be easily removed, as the ZIF connector is the only thing holding it in place.
    • Next up is removing the volume button assembly. Another easy removal, simply pull the assembly away from the device and you're done with the removal process.
    询问修复机器人
    添加评论
  5. Alcatel One Touch Pop 7 Rear Camera Replacement, Rear Camera: 步骤 5 中的图像 1,2 Alcatel One Touch Pop 7 Rear Camera Replacement, Rear Camera: 步骤 5 中的图像 2,2
    在这个步骤中使用的工具:
    • The camera is in the top left corner of the tablet. To begin removal, use the tweezers to gently disconnect the ribbon cable attached to the camera.
    添加评论
  6. Alcatel One Touch Pop 7 Rear Camera Replacement: 步骤 6 中的图像 1,2 Alcatel One Touch Pop 7 Rear Camera Replacement: 步骤 6 中的图像 2,2
    • Pull the actual camera piece from the camera slot. It may stick a bit but it shouldn't be too difficult.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
Riley Cooper
于10/10/16注册
926 声望
创作了5篇指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 28
总计 1,070
