跳转到主内容
加入维修社区 - 创建账户
AirCard 770S SIM Card Replacement
  1. AirCard 770S SIM Card Replacement, SIM Card: 步骤 1 中的图像 1,1
    • Hold the device with the charging port side facing up.
    询问修复机器人
    添加评论
  2. AirCard 770S SIM Card Replacement: 步骤 2 中的图像 1,1
    • Look to the left of the charging port and peel back the SIM Card slot in order to open it.
    询问修复机器人
    添加评论
  3. AirCard 770S SIM Card Replacement: 步骤 3 中的图像 1,1
    • If there is already a SIM Card in the slot, use your finger to press in the SIM Card so that it will pop out slightly. If it does not pop out the first time, press it in again.
    • The SIM Card is not shown in picture. The red circle is where the SIM Card would be located.
    询问修复机器人
    添加评论
  4. AirCard 770S SIM Card Replacement: 步骤 4 中的图像 1,1
    • Use your fingers and carefully pull out the old SIM Card.
    • The SIM Card is not included in picture. The orange circle is where SIM Card would be located on the device.
    • When reassembling the device, make sure to press in the new SIM Card all the way so that the port can be closed and you can then power on the device.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
团队
Marist, Team S1-G2, Chaterdon Fall 2018 Marist, Team S1-G2, Chaterdon Fall 2018 的会员
MARS-CHATERDON-F18S1G2
3 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 28
总计 2,298
