跳转到主内容
加入维修社区 - 创建账户
Air Filter Replacement
  1. Air Filter Replacement, Filter: 步骤 1 中的图像 1,1
    • Locate air filter grille
    • This is usually found near the thermostat
    • Some systems contain multiple filters
    • Not all duct systems have a filter grill. Some are filtered at the air handling appliance
    询问修复机器人
    添加评论
  2. Air Filter Replacement, Open the grill: 步骤 2 中的图像 1,2 Air Filter Replacement, Open the grill: 步骤 2 中的图像 2,2
    • Pull out both latches so that they are perpendicular to the wall
    • Pull grill open from top center
    询问修复机器人
    添加评论
  3. Air Filter Replacement, Remove used filter: 步骤 3 中的图像 1,1
    • Remove the dirty filter
    询问修复机器人
    添加评论
    • If you aren't sure if the filter is ready to be changed just remember this is what cleans the air you are breathing.
    • Never wash or reuse a disposable filter
    • Pleated filters remove more dirt from the air than fiberglass filters. But their density restricts the air flow more. This can create problems in some systems. Experiment with both and see which is best for you and your system.
    • Filters should be checked every 30 days on residential applications and every 15 days on commercial applications.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 37
总计 584
