跳转到主内容
加入维修社区 - 创建账户
Afterglow Wireless PS3 Controller Joystick Replacement
你所需要的
  1. Afterglow Wireless PS3 Controller Joystick  Replacement, Back Cover: 步骤 1 中的图像 1,2 Afterglow Wireless PS3 Controller Joystick  Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Lay the controller face down on a flat surface and remove the seven 9mm Phillips #0 screws on the back of the controller.
    • Lift up and remove the controller back plate.
    添加评论
  2. Afterglow Wireless PS3 Controller Joystick  Replacement, Joystick: 步骤 2 中的图像 1,1
    • Carefully remove the battery by lifting it straight up from its place.
    • Keep in mind that the red and black battery wires are attached to the motherboard. Handle these with care.
    询问修复机器人
    添加评论
  3. Afterglow Wireless PS3 Controller Joystick  Replacement: 步骤 3 中的图像 1,1
    • Unscrew the four 9mm Phillips #0 screws that are attached to both joy stick control mini-motherboards. There are two screws for each mini-motherboard.
    询问修复机器人
    添加评论
  4. Afterglow Wireless PS3 Controller Joystick  Replacement: 步骤 4 中的图像 1,2 Afterglow Wireless PS3 Controller Joystick  Replacement: 步骤 4 中的图像 2,2
    • Jiggle both joy stick control mini-motherboards out of their holding place.
    询问修复机器人
    添加评论
  5. Afterglow Wireless PS3 Controller Joystick  Replacement: 步骤 5 中的图像 1,3 Afterglow Wireless PS3 Controller Joystick  Replacement: 步骤 5 中的图像 2,3 Afterglow Wireless PS3 Controller Joystick  Replacement: 步骤 5 中的图像 3,3
    • Firmly grip the joystick housing with your forefingers by the yellow squares.
    • Use your other hand to get a grip on the black plastic joystick and pull directly away from the housing.
    • This will take some force to remove.
    • Try not to use the motherboard for leverage because it is delicate.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
12等其他人完成本指南。
Aj Coello
于02/17/17注册
1,164 声望
创作了6篇指南
团队
USF Tampa, Team S19-G5, Hoffman Spring 2017 USF Tampa, Team S19-G5, Hoffman Spring 2017 的会员
USFT-HOFFMAN-S17S19G5
4 名成员
创作了20篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 28
过去 30 天: 151
总计 5,576
