跳转到主内容
加入维修社区 - 创建账户
Acer Aspire 5253 RAM Replacement
你所需要的
    1. Acer Aspire 5253 RAM Replacement, Battery: 步骤 1 中的图像 1,1
      • Turn the laptop over.
      询问修复机器人
      添加评论
    2. Acer Aspire 5253 RAM Replacement: 步骤 2 中的图像 1,1
      • "Unlock" your battery by moving the switch as shown so that an unlocked lock on a red background is shown.
      询问修复机器人
      添加评论
    3. Acer Aspire 5253 RAM Replacement: 步骤 3 中的图像 1,1
      • Next move the other switch, while the unlocked symbol is still showing. The battery should pop up, and no longer be flush with the bottom of the laptop.
      询问修复机器人
      添加评论
    4. Acer Aspire 5253 RAM Replacement: 步骤 4 中的图像 1,1
      • Now remove the battery by lifting it out of the laptop by the side closest to the switches.
      询问修复机器人
      添加评论
    5. Acer Aspire 5253 RAM Replacement: 步骤 5 中的图像 1,1
      • You have successfully removed the battery. Congratulations!
      询问修复机器人
      添加评论
    1. Acer Aspire 5253 RAM Replacement, Back Cover Panel: 步骤 6 中的图像 1,1
      • Now, locate the two screws that hold the back cover panel onto the laptop.
      询问修复机器人
      添加评论
    2. Acer Aspire 5253 RAM Replacement: 步骤 7 中的图像 1,1
      • Unscrew both of the screws that are holding the back panel in place with the Philips #00 head.
      • The screws are 3/8" in length and have a 1/4" head.
      询问修复机器人
      添加评论
    3. Acer Aspire 5253 RAM Replacement: 步骤 8 中的图像 1,2 Acer Aspire 5253 RAM Replacement: 步骤 8 中的图像 2,2
      • Once both screws have been removed use a plastic opening tool to lift the panel up. Starting with the indented notch , and moving left and right from there.
      询问修复机器人
      添加评论
    4. Acer Aspire 5253 RAM Replacement: 步骤 9 中的图像 1,1
      • After the panel has been loosened by the plastic opening tool, take your finger, place it in the gap, and remove the panel from the laptop.
      添加评论
    1. Acer Aspire 5253 RAM Replacement, RAM: 步骤 10 中的图像 1,1
      • Now, locate the RAM.
      询问修复机器人
      添加评论
    2. Acer Aspire 5253 RAM Replacement: 步骤 11 中的图像 1,1
      • Locate the two metal pieces on both sides of the RAM that are holding it in place.
      询问修复机器人
      添加评论
    3. Acer Aspire 5253 RAM Replacement: 步骤 12 中的图像 1,1
      • Pull the tabs apart to remove the RAM.
      • The RAM will pop up once they are pried open.
      询问修复机器人
      添加评论
    4. Acer Aspire 5253 RAM Replacement: 步骤 13 中的图像 1,2 Acer Aspire 5253 RAM Replacement: 步骤 13 中的图像 2,2
      • Carefully slide the RAM out of the compartment.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
6等其他人完成本指南。
团队
Cal Poly, Team 8-11, Regan Spring 2014 Cal Poly, Team 8-11, Regan Spring 2014 的会员
CPSU-REGAN-S14S8G11
4 名成员
创作了15篇指南
1指南评论
which bus-ram acer 5253 can use? i know it use bus 1066 but i don't know with bus 1666 how is machine active?
nhanblack1996 - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 54
总计 4,547
