跳转到主内容
加入维修社区 - 创建账户
AT-LP60X Setup Guide
    1. AT-LP60X Setup Guide, Place Turntable: 步骤 1 中的图像 1,2 AT-LP60X Setup Guide, Place Turntable: 步骤 1 中的图像 2,2
      • Place your turntable on a clear, flat surface.
      • Ensure there is no power connected to the turntable at this time.
      询问修复机器人
      添加评论
    2. AT-LP60X Setup Guide, Locate and Install Platter/Belt: 步骤 2 中的图像 1,1
      • Obtain the silver metal platter.
      • Verify that the belt is installed around the inner ring of the platter.
      询问修复机器人
      添加评论
    3. AT-LP60X Setup Guide, Install Platter: 步骤 3 中的图像 1,2 AT-LP60X Setup Guide, Install Platter: 步骤 3 中的图像 2,2
      • Place the platter on the center spindle.
      • Rotate the platter to show the gold pulley of the motor.
      • Stretch the belt from the platter over the gold pulley of the motor.
      询问修复机器人
      添加评论
    4. AT-LP60X Setup Guide, Preform Mechanical Reset: 步骤 4 中的图像 1,2 AT-LP60X Setup Guide, Preform Mechanical Reset: 步骤 4 中的图像 2,2
      • Place the slipmat on top of the platter and press the STOP button.
      • With your right hand, hold the tone arm in place.
      • [OPTIONAL] use the included hook and twist tie for this step.
      • With your left hand, rotate the platter clockwise about 10 times.
      • You should hear a series of clicks and pops.
      询问修复机器人
      添加评论
    5. AT-LP60X Setup Guide, Reconnect Turntable: 步骤 5 中的图像 1,1
      • Reconnect the power supply.
      • Connect the 3.5mm to RCA to your speakers.
      • For powered speakers the output switch should be in "LINE", if connecting to an amp/phono input the output should be in "PHONO"
      • The output switch position does not matter if you are connecting to a Bluetooth speaker.
      询问修复机器人
      添加评论
    6. AT-LP60X Setup Guide, Prepare Tonearm: 步骤 6 中的图像 1,3 AT-LP60X Setup Guide, Prepare Tonearm: 步骤 6 中的图像 2,3 AT-LP60X Setup Guide, Prepare Tonearm: 步骤 6 中的图像 3,3
      • Remove the clear plastic cover from the stylus (if present) by sliding the COVER ONLY directly towards the front of the turntable.
      • Unsecure the twist tie from the built-in hook (if present).
      • Ensure the tone arm lift button is in the outward position.
      • The setup is now complete and you are ready to try a record!
      询问修复机器人
      添加评论
结论
If you have any trouble setting up your turntable and/or a new problem arises, feel free to contact a technician at (330)686-2600 ext.5004 or service@atus.com
取消:我没有完成这个指南。
另外一个人完成了本指南。
Anthony @ ATUS
于02/28/19注册
1,216 声望
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 22
过去 30 天: 119
总计 1,252
