跳转到主内容
加入维修社区 - 创建账户
ASUS VG248 Disassembly
你所需要的
    1. ASUS VG248 Disassembly, ASUS VG248 Disassembly: 步骤 1 中的图像 1,2 ASUS VG248 Disassembly, ASUS VG248 Disassembly: 步骤 1 中的图像 2,2
      • Before you begin, lay the monitor face down on a smooth, clean surface.
      • Four rubbery covers hide four screws in the rear of the monitor.
      • Pry out the plastic covers with a stiff pointed tool, like a metal spudger.
      询问修复机器人
      添加评论
    2. ASUS VG248 Disassembly: 步骤 2 中的图像 1,1
      • Remove the four 13.4 mm Philips #1 screws securing the monitor stand.
      询问修复机器人
      添加评论
    3. ASUS VG248 Disassembly: 步骤 3 中的图像 1,2 ASUS VG248 Disassembly: 步骤 3 中的图像 2,2
      • Remove the stand from the display.
      询问修复机器人
      添加评论
    4. ASUS VG248 Disassembly: 步骤 4 中的图像 1,2 ASUS VG248 Disassembly: 步骤 4 中的图像 2,2
      • The display bezel is held to the rear case by plastic clips that can be released by pulling straight up on the bezel.
      • Rather than use any prying tools that could damage the LCD, it's best to just pull with your fingers. A thin cloth will both protect your fingertips and prevent you from smudging the LCD.
      • Lay the cloth over one of the long edges of the display.
      • Grip the side of the bezel through the cloth and lift straight up. A few clips in the center will pop free.
      • Be careful to pull straight up, and not pry against the display. Pushing down on the display could damage it.
      询问修复机器人
      添加评论
    5. ASUS VG248 Disassembly: 步骤 5 中的图像 1,2 ASUS VG248 Disassembly: 步骤 5 中的图像 2,2
      • Repeat the procedure around the display, lifting up the center of the next side.
      询问修复机器人
      添加评论
    6. ASUS VG248 Disassembly: 步骤 6 中的图像 1,2 ASUS VG248 Disassembly: 步骤 6 中的图像 2,2
      • Move around to the other long side and lift up on the center of the bezel.
      询问修复机器人
      添加评论
    7. ASUS VG248 Disassembly: 步骤 7 中的图像 1,2 ASUS VG248 Disassembly: 步骤 7 中的图像 2,2
      • Grip the center of the final side and lift the bezel away from the rear case.
      询问修复机器人
      添加评论
    8. ASUS VG248 Disassembly: 步骤 8 中的图像 1,2 ASUS VG248 Disassembly: 步骤 8 中的图像 2,2
      • Now that you've freed the centers of the four sides, it's time to move on to the corners.
      • Each corner is secured by two large clips that can't be freed by just pulling straight up like you did with the sides.
      • In the next step, you'll be pushing in on the corner clip on the left of the bottom edge of the bezel.
      询问修复机器人
      添加评论
    9. ASUS VG248 Disassembly: 步骤 9 中的图像 1,2 ASUS VG248 Disassembly: 步骤 9 中的图像 2,2
      在这个步骤中使用的工具:
      Jimmy
      $7.95
      • Using a thin stiff prying device, like a Jimmy, press in against the bottom clip in the lower left corner (beneath the HDMI logo).
      • While pressing the clip in, pull up on the lower edge of the bezel. The entire corner should pop free.
      询问修复机器人
      添加评论
    10. ASUS VG248 Disassembly: 步骤 10 中的图像 1,3 ASUS VG248 Disassembly: 步骤 10 中的图像 2,3 ASUS VG248 Disassembly: 步骤 10 中的图像 3,3
      • Once you've freed one corner, you should be able to gently twist the bezel off, freeing all of the remaining corners.
      • If any corners are particularly stubborn, repeat the previous step on the difficult corner.
      询问修复机器人
      添加评论
    11. ASUS VG248 Disassembly: 步骤 11 中的图像 1,1
      • Remove the bezel.
      询问修复机器人
      添加评论
    12. ASUS VG248 Disassembly: 步骤 12 中的图像 1,2 ASUS VG248 Disassembly: 步骤 12 中的图像 2,2
      • Lift the LCD out of the rear case.
      • The row of adjustment buttons will come out of the case with the display, attached by a thin ribbon cable. Take care not to damage the cable.
      询问修复机器人
      添加评论
    13. ASUS VG248 Disassembly: 步骤 13 中的图像 1,1
      • With the casing removed, you now have access to the button board, cables, and the housing over the motherboard components.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
23等其他人完成本指南。
Sam Goldheart
于10/18/12注册
477,842 声望
创作了538篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了51,039篇指南
11指南评论
Do you know of any place that sell the replacement lcd screen?
treymcbrd - 回复 分享
Hi there, I have a little thunderbug trapped in the LCD is it possible to take the metal casing at the front of to reomve said bug? Thanks
TJ Grainger - 回复 分享
You could yes, but be very careful NOT to introduce dust into the panel!
Bertus van den Dikkenberg - 回复 分享
Hi. A really small bug got stuck within my screen and I accidentally squished it so now it’s dead in there and I want to clean it. How would I remove the top layer of the screen? Because from what I can see it seems like it got squished between the glass and the actual LCD screen itself.
Carl Viernes - 回复 分享
Me too, same issue, a very small bug I thaught was outside, acutally was inside and I squeezed it. It's very small but the dot is disturbing.
Is it possibile to take a part the layers of the LCD screen?
I have an ASUS PA248
Thank you
Piero - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 20
过去 7 天: 113
过去 30 天: 684
总计 137,729
