简介
The back panel is an essential component that protects the internal hardware. This guide walks you through the necessary tools, preparation steps, and the complete replacement process to ensure a successful repair. With proper care and attention to detail, you'll be able to replace your ASUS Q536F back panel efficiently and safely.
你所需要的
Remove ten 2 mm screws using a Phillips #0 screwdriver.
Remove the screw in the center using a T4 Torx screwdriver.
Use an iFixit opening tool to pry open the back panel.
