跳转到主内容
加入维修社区 - 创建账户
ASUS MeMo Pad FHD10 Battery Replacement
你所需要的
    1. ASUS MeMo Pad FHD10 Battery Replacement, Battery: 步骤 1 中的图像 1,2 ASUS MeMo Pad FHD10 Battery Replacement, Battery: 步骤 1 中的图像 2,2
      • Make sure that the device is turned off as a precaution.
      • Unplug the charger and remove any memory card you may have in the device.
      • Wedge the plastic opening tool between the front and back cover on every side.
      • Slide the plastic opening tool back and forth to make sure that the back cover is disconnected.
      • Once disconnected, remove the back cover from the device screen.
      询问修复机器人
      添加评论
    2. ASUS MeMo Pad FHD10 Battery Replacement: 步骤 2 中的图像 1,2 ASUS MeMo Pad FHD10 Battery Replacement: 步骤 2 中的图像 2,2
      在这个步骤中使用的工具:
      • Remove the protective copper sticker and all tape fixed on the device.
      • Using tweezers, remove the ribbon cable from their connections attached to the motherboard.
      • While using the tweezers, make sure to use minimum force and precision to avoid damaging any components.
      询问修复机器人
      添加评论
    3. ASUS MeMo Pad FHD10 Battery Replacement: 步骤 3 中的图像 1,2 ASUS MeMo Pad FHD10 Battery Replacement: 步骤 3 中的图像 2,2
      • Remove the four 2 mm Phillips #00 screws holding the battery tray in place.
      询问修复机器人
      添加评论
    4. ASUS MeMo Pad FHD10 Battery Replacement: 步骤 4 中的图像 1,3 ASUS MeMo Pad FHD10 Battery Replacement: 步骤 4 中的图像 2,3 ASUS MeMo Pad FHD10 Battery Replacement: 步骤 4 中的图像 3,3
      • Locate the battery cable attached to the motherboard. Using the same technique used on the ribbons, do the same with the battery.
      • Remove the battery from the device. Once removed, use the plastic tool to separate the metal frame from the battery.
      • When separating the metal frame, be sure to hold on in the center as the battery is two separate cells.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
5等其他人完成本指南。
Dmitry
于01/21/15注册
391 声望
创作了3篇指南
团队
USF Tampa, Team 9-5, Blackwell Winter 2015 USF Tampa, Team 9-5, Blackwell Winter 2015 的会员
USFT-BLACKWELL-W15S9G5
4 名成员
创作了10篇指南
1指南评论
Where i can get new battery for this tablet?
Night Knight - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 10
过去 30 天: 43
总计 10,792
