跳转到主内容
加入维修社区 - 创建账户
ASUS EEE PC701SD-WHI004X Keyboard Replacement
你所需要的
    1. ASUS EEE PC701SD-WHI004X Keyboard Replacement, Battery: 步骤 1 中的图像 1,2 ASUS EEE PC701SD-WHI004X Keyboard Replacement, Battery: 步骤 1 中的图像 2,2
      • Flip the laptop over, you should see two battery tabs.
      • Slide the right tab towards the right. The orange dot should be visible. This tab will be locked open.
      询问修复机器人
      添加评论
    2. ASUS EEE PC701SD-WHI004X Keyboard Replacement: 步骤 2 中的图像 1,2 ASUS EEE PC701SD-WHI004X Keyboard Replacement: 步骤 2 中的图像 2,2
      • While holding the left tab towards the left. Gently slide the battery out of the laptop.
      添加评论
    1. ASUS EEE PC701SD-WHI004X Keyboard Replacement, Keyboard: 步骤 3 中的图像 1,3 ASUS EEE PC701SD-WHI004X Keyboard Replacement, Keyboard: 步骤 3 中的图像 2,3 ASUS EEE PC701SD-WHI004X Keyboard Replacement, Keyboard: 步骤 3 中的图像 3,3
      • Push the 3 tabs at the top of the keyboard in and down one at a time using a nylon spudger.
      • Once the three tabs have been pushed in, gently pry the top of the keyboard until it begins to hinge out of its slot.
      • The keyboard is still attached by a cable. Be careful when removing not to damage the cable. Do not yank the keyboard out.
      询问修复机器人
      添加评论
    2. ASUS EEE PC701SD-WHI004X Keyboard Replacement: 步骤 4 中的图像 1,3 ASUS EEE PC701SD-WHI004X Keyboard Replacement: 步骤 4 中的图像 2,3 ASUS EEE PC701SD-WHI004X Keyboard Replacement: 步骤 4 中的图像 3,3
      • Push the two sides of the ribbon cable connector away from yourself. This will unseat the ribbon cable.
      • Once the tabs are unseated, you can gently remove the ribbon cable by pulling it out of its slot. The keyboard can now be removed.
      • To be on the safe side, it’s better to use a nylon spudger, rather than the metal spudger shown in the picture.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
mir
于03/24/17注册
409 声望
创作了3篇指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 31
总计 946
