跳转到主内容
加入维修社区 - 创建账户
APEX AP-GS918 Speakers Replacement
你所需要的
    1. APEX AP-GS918 Speakers Replacement, Power/Volume Button: 步骤 1 中的图像 1,3 APEX AP-GS918 Speakers Replacement, Power/Volume Button: 步骤 1 中的图像 2,3 APEX AP-GS918 Speakers Replacement, Power/Volume Button: 步骤 1 中的图像 3,3
      • To begin, locate the two 4.9mm Phillips #00 screws at the top corners of the case and remove them.
      询问修复机器人
      添加评论
    2. APEX AP-GS918 Speakers Replacement: 步骤 2 中的图像 1,3 APEX AP-GS918 Speakers Replacement: 步骤 2 中的图像 2,3 APEX AP-GS918 Speakers Replacement: 步骤 2 中的图像 3,3
      • Squeeze the plastic opening tool in between the seam where the screen joins the plastic case.
      • Begin separating the bottom of the case from the screen by carefully going around the whole edge of the case and slowly prying it apart.
      • Be careful when separating the lids because the wires holding the speaker to the motherboard are very short.
      询问修复机器人
      添加评论
    3. APEX AP-GS918 Speakers Replacement: 步骤 3 中的图像 1,2 APEX AP-GS918 Speakers Replacement: 步骤 3 中的图像 2,2
      在这个步骤中使用的工具:
      • Carefully place the bottom lid next to the screen case. The power/speaker buttons should be visible at the corner of the lid. Remove the buttons with the tweezers.
      询问修复机器人
      添加评论
    1. APEX AP-GS918 Speakers Replacement, Speakers: 步骤 4 中的图像 1,3 APEX AP-GS918 Speakers Replacement, Speakers: 步骤 4 中的图像 2,3 APEX AP-GS918 Speakers Replacement, Speakers: 步骤 4 中的图像 3,3
      • The speaker is attached to the bottom lid with with a small amount of glue and the wires are soldered to the motherboard.
      • In order to remove the speaker you will have to desolder the wires connected to the motherboard.
      • Start by peeling back the black electrical tape covering the motherboard components
      • You will also need to remove the black cloth tape covering the wire contact points.
      询问修复机器人
      添加评论
    2. APEX AP-GS918 Speakers Replacement: 步骤 5 中的图像 1,2 APEX AP-GS918 Speakers Replacement: 步骤 5 中的图像 2,2
      • Now that the contacts are exposed, you can desolder them.
      • Make sure to allow ample time (at least 5-8 minutes or more) for the soldering iron to heat up. Otherwise, the solder won't melt.
      • Touch the hot iron to the contact points and gently pull on the wires to loosen them from the solder. They should release easily.
      • Make sure not to touch the contact points after desoldering them because they will remain very hot for a short while afterwards.
      • The speaker can now be removed. You may need to pull it with some force since there is a small bead of hot glue holding the speaker to its housing
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
团队
USF Tampa, Team 9-1, Leahy Winter 2015 USF Tampa, Team 9-1, Leahy Winter 2015 的会员
USFT-LEAHY-W15S9G1
3 名成员
创作了9篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 13
过去 30 天: 44
总计 558
