简介
The microphone in this device is located on the circuit board, below the speakers a speaker mount.
Before attempting to replace anything, it is recommended that you look at this device’s troubleshooting guide.
This procedure is necessary if the microphone is broken and not allowing the user to make calls through the device. The procedure requires tools to open the speaker and unscrew the fastening screws. Soldering experience is also suggested.
你所需要的
Use the plastic opening tool to pry off the screen.
Remove the screen from the device.
即将完成!
结论
