跳转到主内容
ABXY/D-pad Conductive Sticker Replacement
你所需要的
  1. ABXY/D-pad Conductive Sticker Replacement, Back Cover Removal Preparation: 步骤 1 中的图像 1,1
    • Before starting the disassembly, remove
    • The stylus
    • Any game cartridge
    • The SD card
  2. ABXY/D-pad Conductive Sticker Replacement, Back Cover Removal: 步骤 2 中的图像 1,1
    • Unscrew the four 6mm tri-point screws located at the four corners of the bottom panel.
  3. ABXY/D-pad Conductive Sticker Replacement, Case Separation: 步骤 3 中的图像 1,2 ABXY/D-pad Conductive Sticker Replacement, Case Separation: 步骤 3 中的图像 2,2
    • Be careful when separating the bottom panel from the front casing to avoid breaking the three cables connected to the motherboard (two on each side and one in the rear).
    • Using a spudger, separate the back panel from the front casing by gently prying around the panel.
    • There are many clips along the hinge of the case, so it is recommended to work your way along one short side and the two long sides before finishing the last short side.
  4. ABXY/D-pad Conductive Sticker Replacement: 步骤 4 中的图像 1,3 ABXY/D-pad Conductive Sticker Replacement: 步骤 4 中的图像 2,3 ABXY/D-pad Conductive Sticker Replacement: 步骤 4 中的图像 3,3
    在这个步骤中使用的工具:
    • Using tweezers, disconnect the two cables that connect the rear buttons on either side to the motherboard by gently pulling them upwards.
  5. ABXY/D-pad Conductive Sticker Replacement, Battery Removal: 步骤 5 中的图像 1,2 ABXY/D-pad Conductive Sticker Replacement, Battery Removal: 步骤 5 中的图像 2,2
    • Using a spudger, lift out the battery.
    • Be aware that there is a sticky pad holding the battery into its tray. It may be necessary to use multiple tools to gently pry the battery away from the tray and motherboard.
  6. ABXY/D-pad Conductive Sticker Replacement, Motherboard: 步骤 6 中的图像 1,2 ABXY/D-pad Conductive Sticker Replacement, Motherboard: 步骤 6 中的图像 2,2
    在这个步骤中使用的工具:
    • There are 8 ribbon cables that need to be removed as shown in the picture.
    • 2 of connectors (in green) are friction fit, unlike the rest of the connectors. Remove the cable by pulling it out gently. Do not attempt to open or unlatch these connectors in any way. Doing so will break them.
    • For the remaining 6 (in red), use a pair of tweezers to flip the latches up and pull the ribbon cable out.
    • Note that the second picture shows a broken ribbon connector next to the joystick ribbon connector (to the right of the red arrow). Do not attempt to unlatch this connector as shown in the picture!
  7. ABXY/D-pad Conductive Sticker Replacement: 步骤 7 中的图像 1,2 ABXY/D-pad Conductive Sticker Replacement: 步骤 7 中的图像 2,2
    • Unplug the following wires from the motherboard using a pair of tweezers.
  8. ABXY/D-pad Conductive Sticker Replacement: 步骤 8 中的图像 1,2 ABXY/D-pad Conductive Sticker Replacement: 步骤 8 中的图像 2,2
    • Remove the seven 4.4 mm screws using a J00 (or iFixit's Phillips #00) screwdriver bit.
    • Remove the motherboard from the device.
  9. ABXY/D-pad Conductive Sticker Replacement, ABXY/D-pad Conductive Sticker: 步骤 9 中的图像 1,1
    • Flip the board over so the cartridge slot is on the bottom
    • Peel off the damaged sticker and replace it with the new one
    • ABXY buttons
    • D-pad
    • If the new sticker doesn't fit properly, you can cut it apart and stick each pad down separately. As long as they're properly aligned and secure, the buttons will still work normally
结论
2等其他人完成本指南。
darth mango
于03/13/23注册
3,032 声望
创作了3篇指南
团队
Kid fixers Kid fixers 的会员
Community
183 名成员
创作了256篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 38
过去 30 天: 139
总计 2,344
