跳转到主内容
加入维修社区 - 创建账户
8BitDo NES30 Pro Gamepad Button Replacement
你所需要的
    1. 8BitDo NES30 Pro Gamepad Button Replacement, Button: 步骤 1 中的图像 1,2 8BitDo NES30 Pro Gamepad Button Replacement, Button: 步骤 1 中的图像 2,2
      • Hold the controller with its back facing towards you.
      • Insert an opening pick between the L1 or R1 button and the backplate, and pry the backplate off of the controller.
      询问修复机器人
      添加评论
    2. 8BitDo NES30 Pro Gamepad Button Replacement: 步骤 2 中的图像 1,2 8BitDo NES30 Pro Gamepad Button Replacement: 步骤 2 中的图像 2,2
      • Place the controller face down on a solid surface.
      • Remove the seven screws with the Phillips #00 screwdriver.
      询问修复机器人
      添加评论
    3. 8BitDo NES30 Pro Gamepad Button Replacement: 步骤 3 中的图像 1,1
      • Lift the body of the controller up and away from the controller's face and buttons.
      询问修复机器人
      添加评论
    4. 8BitDo NES30 Pro Gamepad Button Replacement: 步骤 4 中的图像 1,2 8BitDo NES30 Pro Gamepad Button Replacement: 步骤 4 中的图像 2,2
      • Lift away the black rubber pads that sit between the face buttons and body of the controller.
      询问修复机器人
      添加评论
    5. 8BitDo NES30 Pro Gamepad Button Replacement: 步骤 5 中的图像 1,1
      • Lift the buttons out of the face of the controller.
      询问修复机器人
      添加评论
    6. 8BitDo NES30 Pro Gamepad Button Replacement: 步骤 6 中的图像 1,2 8BitDo NES30 Pro Gamepad Button Replacement: 步骤 6 中的图像 2,2
      • Align the notches of the face buttons to put them back into place.
      • Each button has a unique notch pattern so it can't be replaced incorrectly.
      • Attach the rubber pads by placing their smaller and larger holes around the matching size pegs.
      添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
4指南评论
Hello there, any idea where I can find those black rubber pads for replacement ? mine is torn.
Thx
Ben Kakita - 回复 分享
sorry, i try to search every where, have a tone for other controller, even have for 8bitdo snes, but not for nes 30 pro.
if you find it, answer on that chat. Good luck
Freeman loran - 回复 分享
I wrote 8BitDo support, and explained the issue. They sent me some pads for the price of postage, but only for the buttons -- they didn't send any for the d-pad, which I feel is probably an error on their part.
Izaak Xavier - 回复 分享
The screws in the N30 Pro are #6 Torx now
Matt Baker - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 14
过去 30 天: 60
总计 3,246
