跳转到主内容
加入维修社区 - 创建账户
2012 Ford Fusion Battery Replacement
你所需要的
    1. 2012 Ford Fusion Battery Replacement, Battery: 步骤 1 中的图像 1,3 2012 Ford Fusion Battery Replacement, Battery: 步骤 1 中的图像 2,3 2012 Ford Fusion Battery Replacement, Battery: 步骤 1 中的图像 3,3
      • In order to access the car's battery, the hood must first be opened. To open the hood, begin by pulling the hood release latch.
      询问修复机器人
      添加评论
    2. 2012 Ford Fusion Battery Replacement: 步骤 2 中的图像 1,3 2012 Ford Fusion Battery Replacement: 步骤 2 中的图像 2,3 2012 Ford Fusion Battery Replacement: 步骤 2 中的图像 3,3
      • In order to get the hood fully opened after pulling the release, a small latch located between the grille and hood must be lifted up.
      询问修复机器人
      添加评论
    3. 2012 Ford Fusion Battery Replacement: 步骤 3 中的图像 1,3 2012 Ford Fusion Battery Replacement: 步骤 3 中的图像 2,3 2012 Ford Fusion Battery Replacement: 步骤 3 中的图像 3,3
      • Locate the battery near the top right side of the car if looking at it from the front, and also pull back the red rubber guard covering the positive terminal as shown below.
      询问修复机器人
      添加评论
    4. 2012 Ford Fusion Battery Replacement: 步骤 4 中的图像 1,3 2012 Ford Fusion Battery Replacement: 步骤 4 中的图像 2,3 2012 Ford Fusion Battery Replacement: 步骤 4 中的图像 3,3
      • First locate the negative terminal and the nut that is holding the battery contact in place. To remove this, use the 8mm socket and ratchet and rotate nut counter-clockwise until it is loose enough to lift from terminal.
      • Be careful when handling the terminals to not touch both of them at the same time as that can cause serious harm. Always remove one terminal at a time starting with the negative terminal so you do not short out the battery.
      询问修复机器人
      添加评论
    5. 2012 Ford Fusion Battery Replacement: 步骤 5 中的图像 1,3 2012 Ford Fusion Battery Replacement: 步骤 5 中的图像 2,3 2012 Ford Fusion Battery Replacement: 步骤 5 中的图像 3,3
      • Next locate the positive terminal with the red rubber cover. Pull back the cover and locate the nut holding the battery contact in place. Remove the contact by using the 8mm socket and ratchet to turn the nut counter-clockwise until it is loose enough to lift from terminal.
      询问修复机器人
      添加评论
    6. 2012 Ford Fusion Battery Replacement: 步骤 6 中的图像 1,2 2012 Ford Fusion Battery Replacement: 步骤 6 中的图像 2,2
      • Locate the 8mm bolt on the left side of the battery that is holding the battery in place. Using the 8mm socket and ratchet, remove bolt by turning counter-clockwise until the bolt fully comes out of the holder.
      • Remove bolt along with holder as pictured.
      询问修复机器人
      添加评论
    7. 2012 Ford Fusion Battery Replacement: 步骤 7 中的图像 1,3 2012 Ford Fusion Battery Replacement: 步骤 7 中的图像 2,3 2012 Ford Fusion Battery Replacement: 步骤 7 中的图像 3,3
      • Now that all battery contacts have been removed and the battery holder has been removed, you can simply pull the battery straight up out of its original position as shown.
      询问修复机器人
      添加评论
结论
To reinstall the battery, follow these instructions in reverse order.
取消:我没有完成这个指南。
4等其他人完成本指南。
2指南评论
Thanks. Very Nice!
Rafael Amorim - 回复 分享
Thank you! Can you also tell me which terminal is attached to the chassis? I'm assuming it's the negative one but you know what they say about assuming
Anita R Burke - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 25
过去 30 天: 122
总计 20,400
