跳转到主内容
2011-2014 Jeep Grand Cherokee Key Fob Battery Replacement
你所需要的
  1. 2011-2014 Jeep Grand Cherokee Key Fob Battery Replacement, Key Fob Battery: 步骤 1 中的图像 1,3 2011-2014 Jeep Grand Cherokee Key Fob Battery Replacement, Key Fob Battery: 步骤 1 中的图像 2,3 2011-2014 Jeep Grand Cherokee Key Fob Battery Replacement, Key Fob Battery: 步骤 1 中的图像 3,3
    • Here is the FOB for my Jeep. It decided to finally quit. The functionality became less over the last couple of weeks and required frequent attempts to unlock the vehicle etc.
    • Remove the key by moving
    • locking hatch to the left side first.
    • The two halves where the FOB needs to be split are clearly visible
  2. 2011-2014 Jeep Grand Cherokee Key Fob Battery Replacement: 步骤 2 中的图像 1,3 2011-2014 Jeep Grand Cherokee Key Fob Battery Replacement: 步骤 2 中的图像 2,3 2011-2014 Jeep Grand Cherokee Key Fob Battery Replacement: 步骤 2 中的图像 3,3
    • Using a plastic opening tool (or finger nail, guitar pick etc.) start at the front of the FOB to separate it
    • Moving the tool along the split line with slight sideways pressure
    • will separate the FOB easily.
  3. 2011-2014 Jeep Grand Cherokee Key Fob Battery Replacement: 步骤 3 中的图像 1,3 2011-2014 Jeep Grand Cherokee Key Fob Battery Replacement: 步骤 3 中的图像 2,3 2011-2014 Jeep Grand Cherokee Key Fob Battery Replacement: 步骤 3 中的图像 3,3
    • Here is the cleanly opened FOB
    • Bottom half of the FOB contains the CR2032 coin battery
    • Remove the battery by pulling it out of the holder pushing it gently against the spring contacts.
    • Replace the battery following the polarity with the positive side to the body of the FOB
  4. 2011-2014 Jeep Grand Cherokee Key Fob Battery Replacement: 步骤 4 中的图像 1,2 2011-2014 Jeep Grand Cherokee Key Fob Battery Replacement: 步骤 4 中的图像 2,2
    • Insert wisdom here.
结论
12等其他人完成本指南。
oldturkey03
于09/29/10注册
782,402 声望
创作了119篇指南
团队
Global Fixers Global Fixers 的会员
Community
33 名成员
创作了543篇指南
一条评论
Very easy! Thank you!
Cheryl Talley - 回复
添加评论
浏览统计数据:
过去 24 小时: 15
过去 7 天: 87
过去 30 天: 468
总计 71,456
