简介
升级你的硬盘以获得更多的存储空间!
要重新组装你的设备,请按照该指南并按照相反的顺序重新组装。
278等其他人完成本指南。
特别感谢这些译者︰
100%
这些翻译人员帮助我们修复这个世界! 想要作出贡献?
开始翻译 ›
16条评论
Thanks yet again, iFixit! I am not an expert by any stretch of the imagination, but your clear, explicit directions always make me feel like one.
The repair proved even easier than the "moderate" difficulty rating would suggest. The entire process took me about ten minutes—far less time than it would take to even drive to a repair depot or Genius Bar.
Also: I was unable to locally source a spudger or T6 Torx screwdriver, and couldn't afford to wait. No problemo! I was able to easily disconnect the MacBook battery using my fingernails. Also, because the Torx screws protrude slightly, I was able to unscrew them (and screw them into the new drive) using needle-nose pliers.
My new drive is now formatted and being restored using a Time Machine backup.
Very easy if you have a basic understanding of how a computer is put together. Took me about five minutes, honestly. The hardest part was getting a screwdriver that was small enough. The key is to go slow and BE CAREFUL. If you're going to disconnect the battery connector, DON'T PRY IT WITH ANYTHING METAL. That should be common sense, but it probably isn't. Also, take note that the ribbon cable that is attached to the SATA connector is very delicate. Again, be careful and you should be good.
Great guide. Everything was exactly as stated. However, not my HD sits loose in the case. It shifts and clunks every time I pick it up. Did I miss something or should I just open it up and use duct tape.
I had the same issue. You probably forgot to take the torx screws off the old drive and put them on the new drive. See Step 9 for details. I glossed over this, it was easy to miss, but it's definitely in the steps above and probably the cause of your issue.
REALLY straightforward :)
Have a plate or other clean, plain surface - as you unscrew them just lay out the scerws in their physical order and positions on the plate.
I DIDN'T disconnect the battery, but was VERY careful not to touch ANYTHING other than the disk - I guess that's feasibly where an accident might happen.
Go slow, keep touching a metal radiator or similar to ensure there is no static build up, and... DONE! Thanks iFixit :)
Mark Bodha - 回复
