跳转到主内容
2006 Iron Horse Warrior Chain Replacement
你所需要的
  1. 2006 Iron Horse Warrior Chain Replacement, Chain: 步骤 1 中的图像 1,3 2006 Iron Horse Warrior Chain Replacement, Chain: 步骤 1 中的图像 2,3 2006 Iron Horse Warrior Chain Replacement, Chain: 步骤 1 中的图像 3,3
    • Identify the master link on your bicycle chain, push the ends of the master link together and the link will disconnect, it may require a lot of force. If you have done this, skip step 2. If you cannot find one, your chain may not have one.
    • If you do not have a master link on your chain, use the chain breaker to separate any two links of the chain.
  2. 2006 Iron Horse Warrior Chain Replacement: 步骤 2 中的图像 1,2 2006 Iron Horse Warrior Chain Replacement: 步骤 2 中的图像 2,2
    • Arrange the chain in the chain breaker so the connector aligns with the press.
    • Slowly tighten the screw until the connector begins to slide out of the link. DO NOT push the connector all the way out.
    • DO NOT push the connector all the way out, only enough to separate the links. This is essential in reconstructing your chain without purchasing a master link.
    • Now that you have your old chain off, you can either clean it or replace it. If you replace the chain make sure you buy the correct length and size!
  3. 2006 Iron Horse Warrior Chain Replacement: 步骤 3 中的图像 1,3 2006 Iron Horse Warrior Chain Replacement: 步骤 3 中的图像 2,3 2006 Iron Horse Warrior Chain Replacement: 步骤 3 中的图像 3,3
    • Now that you have a new chain, it is time to install it. The process to put a new chain on is a little different from taking it off.
    • Weave the chain thru the rear derailleur, make sure to guide the chain thru the rear chain guard.
    • It can be cramped, pulling down the derailleur can often be helpful.
    • The last image highlights the chains path thru the sprockets.
    • Holding the end of the chain in place, proceed to step 5.
  4. 2006 Iron Horse Warrior Chain Replacement: 步骤 4 中的图像 1,2 2006 Iron Horse Warrior Chain Replacement: 步骤 4 中的图像 2,2
    • Set the chain, with the loose end on top, on the chain ring.
    • Make sure the chain goes thru the guide at the top of the chain ring.
  5. 2006 Iron Horse Warrior Chain Replacement: 步骤 5 中的图像 1,2 2006 Iron Horse Warrior Chain Replacement: 步骤 5 中的图像 2,2
    • Connect the ends of the masterlink and pull, it should snap into place. If not, place the master link above the rear gear, hold the rear tire in place, and give the pedal a push. The stress on the chain should snap the master link into place.
  6. 2006 Iron Horse Warrior Chain Replacement: 步骤 6 中的图像 1,1
    • After such extensive work on the rear tire and chain, it is always a good idea to realign your rear derailleur.
终点
团队
Cal Poly, Team 15-2, Amido Spring 2015 Cal Poly, Team 15-2, Amido Spring 2015 的会员
CPSU-AMIDO-S15S15G2
4 名成员
创作了12篇指南
一条评论
I need to find out chain length
Tod Maudlin - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 9
总计 1,189
