跳转到主内容
1999-2004 Jeep Grand Cherokee Rear Hatch lift supports Replacement
你所需要的
  1. 1999-2004 Jeep Grand Cherokee Rear Hatch lift supports Replacement, Rear hatch lift supports: 步骤 1 中的图像 1,3 1999-2004 Jeep Grand Cherokee Rear Hatch lift supports Replacement, Rear hatch lift supports: 步骤 1 中的图像 2,3 1999-2004 Jeep Grand Cherokee Rear Hatch lift supports Replacement, Rear hatch lift supports: 步骤 1 中的图像 3,3
    • Open the tail gate and either prop it up or use an assistant to hold it.
    • The tail gate is heavy and will fall if not properly supported.
    • The rear hatch has both a left and right lift support strut.
  2. 1999-2004 Jeep Grand Cherokee Rear Hatch lift supports Replacement, Loosen the strut bolts: 步骤 2 中的图像 1,3 1999-2004 Jeep Grand Cherokee Rear Hatch lift supports Replacement, Loosen the strut bolts: 步骤 2 中的图像 2,3 1999-2004 Jeep Grand Cherokee Rear Hatch lift supports Replacement, Loosen the strut bolts: 步骤 2 中的图像 3,3
    • The struts are fastened with T40 Torx head bolts.
    • Use a T40 Torx driver to loosen the bolt
    • The bolt does not remove the strut. It is pressed in to the strut and will be replaced with the new strut.
  3. 1999-2004 Jeep Grand Cherokee Rear Hatch lift supports Replacement, Replace the struts: 步骤 3 中的图像 1,3 1999-2004 Jeep Grand Cherokee Rear Hatch lift supports Replacement, Replace the struts: 步骤 3 中的图像 2,3 1999-2004 Jeep Grand Cherokee Rear Hatch lift supports Replacement, Replace the struts: 步骤 3 中的图像 3,3
    • Completely loosen the bolt securing the strut to the top of the tailgate with a T40 driver.
    • Replace the worn strut with a new one.
    • On this vehicle both struts were replaced. This will stop the tailgate from sagging.
结论
To reassemble your Jeep, follow these instructions in reverse order.
8等其他人完成本指南。
oldturkey03
于09/29/10注册
782,451 声望
创作了119篇指南
团队
Global Fixers Global Fixers 的会员
Community
33 名成员
创作了544篇指南
4条评论
We just had a garage replace the tailgate lift struts on our 2002 Jeep Grand Cherokee. Now the tail is very difficult to pull closed. Is there a way to adjust the struts so that it easier to pull down closed??
Raymond Janko - 回复
Double check the work. Make sure they are mounted the right direction and that all the bolts are properly fastend. There are no adjustments
oldturkey03 -
I need to replace the lower bolt as it snapped in half. Any advice for that?
Dave Hankins - 回复
Use a drill and drill off the head. Remove the strut and use something like a pair of vise-grips and get a grip on the leftover part of the bolt. Try to remove it. If you can/ time to drill it out and retap the thread.
oldturkey03 -
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 53
总计 9,890
