跳转到主内容
加入维修社区 - 创建账户
12-String Takamine G Series Guitar String Replacement
你所需要的
    1. 12-String Takamine G Series Guitar String Replacement, Guitar String: 步骤 1 中的图像 1,3 12-String Takamine G Series Guitar String Replacement, Guitar String: 步骤 1 中的图像 2,3 12-String Takamine G Series Guitar String Replacement, Guitar String: 步骤 1 中的图像 3,3
      • Turn the tuning peg corresponding to the string you want to change clockwise until the string is completely loose.
      • This is only if the string is damaged but not completely broken (if the string is completely broken skip to step 2).
      询问修复机器人
      添加评论
    2. 12-String Takamine G Series Guitar String Replacement: 步骤 2 中的图像 1,2 12-String Takamine G Series Guitar String Replacement: 步骤 2 中的图像 2,2
      • Use wire cutters to take out the pins located on the bridge of the guitar and completely release the string from the guitar.
      询问修复机器人
      添加评论
    3. 12-String Takamine G Series Guitar String Replacement: 步骤 3 中的图像 1,2 12-String Takamine G Series Guitar String Replacement: 步骤 3 中的图像 2,2
      • Place the new string into the hole in the bridge where the pin was taken out.
      询问修复机器人
      添加评论
    4. 12-String Takamine G Series Guitar String Replacement: 步骤 4 中的图像 1,3 12-String Takamine G Series Guitar String Replacement: 步骤 4 中的图像 2,3 12-String Takamine G Series Guitar String Replacement: 步骤 4 中的图像 3,3
      • Place the pin back into the hole to secure the string.
      询问修复机器人
      添加评论
    5. 12-String Takamine G Series Guitar String Replacement: 步骤 5 中的图像 1,1
      • Grab the string and put it through the hole located on the tuning post of the guitar.
      询问修复机器人
      添加评论
    6. 12-String Takamine G Series Guitar String Replacement: 步骤 6 中的图像 1,3 12-String Takamine G Series Guitar String Replacement: 步骤 6 中的图像 2,3 12-String Takamine G Series Guitar String Replacement: 步骤 6 中的图像 3,3
      • Take the string and wrap it around and underneath itself.
      • Pull the string taught.
      • Twist the string over itself and than cut off the excess string.
      询问修复机器人
      添加评论
    7. 12-String Takamine G Series Guitar String Replacement: 步骤 7 中的图像 1,2 12-String Takamine G Series Guitar String Replacement: 步骤 7 中的图像 2,2
      • Turn the tuning peg counterclockwise to tighten the string.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
Rey Navarro
于09/27/23注册
145 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 14
过去 30 天: 47
总计 890
