简介
使用这份指南更换 Steam Deck(LCD屏幕) 的右扳机(R2)组件。虽然基本上一模一样,我们也有更换左扳机(L2)的指南。
更换扳机之后需要校准才能保证它正常工作。 看这里来学习如何校准。
你所需要的
用十字螺丝刀拆卸固定后盖的 8 颗螺丝:
四个 9.5 毫米长的粗螺纹螺丝
四个 5.8 毫米长的细螺纹螺丝
若要重新组装您的设备,请按照相反的顺序执行这些说明。
请将你的电子垃圾送到R2或e- steward认证的回收商。
修理没有按照计划进行? 看看我们的 修理后的故障排除, 或者向Steam Deck 社区 求助。
6等其他人完成本指南。
由衷感谢以下译者:
91%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
4条评论
The shield doesn't need to be removed for this repair. The trigger is difficult to replace. Start with the outer peg first, leftside, and then position the right-side above the peg. Apply pressure to get it over the leg, then continue pressure to get it on the peg. A little tricky, and don't forget to attach the spring first.
My transistor on the left daughterboard is missing. I would like to buy a new transistor and solder it myself. Could you please provide me with the specifications of the transistor or give me a link to purchase one? The L2 button is not working because of it. It has the code "303" on it, you can see it in the images above
