跳转到主内容
更换任天堂Switch背部外壳
你所需要的
  1. 更换任天堂Switch背部外壳, Joy Con 游戏手柄: 步骤 1 中的图像 1,3 更换任天堂Switch背部外壳, Joy Con 游戏手柄: 步骤 1 中的图像 2,3 更换任天堂Switch背部外壳, Joy Con 游戏手柄: 步骤 1 中的图像 3,3
    • 开始维修之前,请确保设备已完全关闭电源。
    • 按住 Joy Con 手柄背面的圆形小按钮。
    • 按住该按钮的同时,向上推动手柄。
    Kann ich diese Anleitung auch für die OLED anwenden? Habe im INet sonst leider nichts brauchbares gefunden.
    Ina Barz - 回复
    backup all your sd card data i had to format mine after this tutorial and lost all my game data
    JustForThisComment?ComeOn - 回复
    do not watch the video! i broke the metal shielding on my switch because they didn't mention a screw!!!
    Macro Man - 回复
  2. 更换任天堂Switch背部外壳, 取下游戏手柄: 步骤 2 中的图像 1,3 更换任天堂Switch背部外壳, 取下游戏手柄: 步骤 2 中的图像 2,3 更换任天堂Switch背部外壳, 取下游戏手柄: 步骤 2 中的图像 3,3
    • 按住手柄背部的圆形按键,向上推动手柄直到将它与主机完全分开。
    • 按相同操作,卸下另一只手柄
  3. 更换任天堂Switch背部外壳, 移除背盖螺丝: 步骤 3 中的图像 1,1
    在这个步骤中使用的工具:
    Magnetic Project Mat
    $19.95
    • 使用 Y00 螺丝刀拧下固定在后盖上的 4 颗 6.3 毫米螺丝。
    • 在整个维修过程中,请妥善保管每一颗螺丝 ,并保证在装回时每颗螺丝都能安装至原来的位置。
    Had to use a Y0 from my kit - the Y00 was too small to get a grip on the screw.
    cday - 回复
    I also had a much easier time with Y0 versus Y00. Y00 felt like it was starting to strip the first screw I tried to remove.
    Joe -
    My screws took a little coaxing before they were all ready to come out of the back plate, but I remedied this by turning the screwdriver as little as possible with each turn. Use almost no pressure, except for at the very beginning of each screw’s first turn.
    nin10doh - 回复
    I think my screws are stripped, any way to get them out?
    Banjomanperson - 回复
    I hear that using a rubber band can help? Not 100% sure on that though.
    Pifase -
    My top 2 screws are stripped, one into triangle, the other circle, rather than triangle spokes.
    AndrewDaPro - 回复
    This happened when I replaced the micro-sd card slot, which turned out to have replaced the broken one with another one that turns out to be broken. I need to fix the fact that when I reapplied the back cover, the vent was misaligned.
    AndrewDaPro -
    I had huge problems removing the bottom two screws. I continued with the next steps and lifted the plastic shell as much as possible while using the screwdriver and it became an ease.
    y0 works best. Press HARD at beginning then ease off to finish.
    J LWsMommy - 回复
    what to do if your screw is stripped??
    suru - 回复
    I haven't tried neither solutions that I am gonna propose here but
    1. Poor some Isopropyl Alcohol, one small drop will do, get a piece of cotton (not any clothing) and dip it in the Isopropyl Alcohol, apply and then try to get a grip with tweezers and turn it out
    OR (I do not reccomend it since it can cause huge damage if done wrong)
    2. Grab a small drill and drill through the screw. Keep in mind; the screw is very small.
    If you do one of these and it goes wrong, I am not responsible for that.
    DongComArts -
    I had to file down the point of the y00 bit. As it came, I was not able to get the back screws out. It would just slip in the screw.
    Dave - 回复
    Y1.5 is correct, perfect fit.
    Orpheus - 回复
    this is so difficult the screwdriver doesnt help AT ALL
    Issa - 回复
  4. 更换任天堂Switch背部外壳, 移除顶部和底部螺丝: 步骤 4 中的图像 1,2 更换任天堂Switch背部外壳, 移除顶部和底部螺丝: 步骤 4 中的图像 2,2
    • 使用 JIS000 螺丝刀,或者 iFixIt PH000 螺丝刀取下用于固定后面板的螺丝:
    • 一颗在主机顶部的散热器出口旁,长度为2.5毫米的螺丝
    • 两颗在主机底部的充电接口两侧,长度为2.5毫米的螺丝
    • 面板上的这些螺丝比较容易滑丝,为了防止滑丝发生,在拆卸过程中请用力向螺丝施加压力,同时缓慢拧动螺丝刀,如果螺丝无法拧出来,尝试换另一个JIS 000 或 PH 000 螺丝刀试一下。
    Hey guys, I tried removing the upper screw and it won't go out(neither will it go in) any tips how to fix this?
    Thanks
    Nemysis - 回复
    The screw boss might be stripped out. Has the device been taken apart before? If you can unscrew it a little bit to get the screw to peek out, maybe try and grab it with some pliers as a last-ditch effort.
    Craig Lloyd -
    I have the same problem. The JIS 000 tool works great on the joy con rails per step 5 but refuses to turn the bottom two 2.5 mm screws as in step 4. These bottom screws are noticeably smaller than the screws as in step 5. The JIS 000 does not get down into these screws. Hopefully they haven’t been stripped by the wrong tool. So is there a JIS tool that is smaller than 000? I’m stuck at this point…
    david brown - 回复
    We used the JIS 3.0mm screwdriver for both top and bottom screws and it worked
    Brooklyn Gardner - 回复
    Used PH00 to get these out with no problem.
    cday - 回复
    Fun fact: these screw into little plastic tabs that stick out of the rear panel. Apparently those tabs are fragile and easy to just break off…
    Benjamin Fritz - 回复
    If the screw is turning but not coming out, the plastic tab that it screws into is probably damaged or broken. You’ll need to try to pry the screw out with tweezers as you unscrew it. It is not the end of the world if you can’t screw these back in during reassembly.
    claudio ocano -
    My screws came out fine. But they are easily stripped with too much pressure on reassmbly
    Jaxon Lee - 回复
    this screws are way too fragile and way too small so be careful when taking them off dont use much force and unscrew also one of them fell somewhere and spent 30 mins searching for it
    Richard Aguirre - 回复
    PH000 will work if you don’t have JIS000. The large IFIXIT kit has both and I lost JIS000. Just be very careful as you can strip the heads when removing or inserting easier.
    Shawn Spivey - 回复
    One thing that worked pretty well for me with the screws not coming out is slightly prying on the back cover to put them under some tension
    Florian Kraupa - 回复
    I just came here to also confirm and say thanks to Florian for the tip. This saved me a lot of time and frustration.
    Jon Nielsen -
    Quick note, these screws are not magnetic. A magnetic screwdriver will hold onto any of the others safely, but you need to be careful not to drop these ones in particular.
    Jason Lane - 回复
    These would just keep rotating and not come out. What worked was, as Florian Kraupa suggested, i slid a plastic pick just between the 2 shells near the screws to prise it open slightly, then unscrewed and out they came. They're the smallest screws I've ever almost not seen before, so be careful with them.
    Susannah Carter - 回复
    Der Tausch von Akku (separate Anleitung) und Lüfter ging einfach vonstatten. Die Anleitung ist echt gut und leicht verständlich. Man sollte aber gewohnt sein, mit extrem kleinen Anschlüssen, Schrauben und Platinen zu arbeiten, da alles da drin recht klein ausgelegt ist und keine Toleranz für grobschlächtiges Arbeiten erlaubt! Meine Switch ist nun wieder wie neu :) - Danke iFixit!
    The swapping of battery (separate instruction) and fan was fairly manageable. The instructions are easy to understand. One should be used to handle with extremely finnicky connectors, screws and circuits as the components are really small and do not allow any tolerance for rough handling at all! My Switch is good as new again :) - Thank you iFixit!
    gerhardkoschany - 回复
    My original switch bought on launch day does not have any of these screws. I'm guessing they fell out since the plastic tabs they attach to are broken. FYI, in case anyone else does not have these screws...
    Michael Crook - 回复
  5. 更换任天堂Switch背部外壳: 步骤 5 中的图像 1,2 更换任天堂Switch背部外壳: 步骤 5 中的图像 2,2
    • 在设备两边,使用 JIS000 螺丝刀(或 iFixit PH000 螺丝刀)拧下2颗长度为3.8毫米,位于中央的中心螺丝(一面一颗)
    • 注意 如图所示,在主机的两面各有五颗螺丝,本步骤只需要拆除最中心的那一颗,其余四颗不需要拆卸。
    I tried my JIS 000 on Step 5 and was unable to get the screw to budge. It’s partner from the other side came right out with no trouble. Don’t really want to narf up the screw, so I bailed out. Anyone else have this issue?
    mrhoyt - 回复
    Could just be torqued down a bit more! I’d recommend making sure the driver bit seats nicely into the screw, apply some downward pressure, and slowly twist to try and back it out. Good luck!
    Craig Lloyd -
    Yeah I’m having this exact issue. Screw stripped and now I’m stuck. Wish I hadn’t even started.
    Ryan Quinn -
    I did finally get it out- one thing I noticed was some of the screws have blue Loctite on the threads. I guess they figure it’ll get tossed around. This underscores the importance of having the correct tools and making double darn sure you are using the correct size, etc.
    mrhoyt - 回复
    What worked for me here was a Phillips 000, not a JIS 000
    Federico Zivolo - 回复
    One of mine is totally stripped. Guess I can’t do anything now.
    Nick - 回复
    My kit only has two screwdriver heads! The package was open when I received it!
    Cynthia Hyland - 回复
    I had this issue as well. Screw was irreparably stripped. If you can get every other screw out, just keep applying pressure with a flat head screw driver right above the stripped screw and try to break the plastic piece holding onto the screw. It's a very minor invisible bit of damage that will allow you to continue the repair.
    Raymond Garrison - 回复
    after getting all the other screws off I just hinged the back part away and it snapped off neatly where the rusted screw is. not the best solution but it worked.
    Steve T -
    One of my screws was SUPER attached too, but after following a bit noticed the one other in the left that got out nicely, had the plastic tab broken already! So I went ahead and broke the other tab too. So the two side screws are now holding nothing. But I think it will work thanks to the other 4 or 5 screws. Too bad!
    carolaclavo -
    i managed to get out one screw by putting a bit of paper over it which gave the screwdriver something to grip. The other side just won't budge and gets worse the more i try.
    Steve T - 回复
    000 is too small, PH00 is right. Incorrect bit size will strip screws.
    Orpheus - 回复
  6. 更换任天堂Switch背部外壳: 步骤 6 中的图像 1,2 更换任天堂Switch背部外壳: 步骤 6 中的图像 2,2
    • 用手指翻起 Switch 主机背部用的支架
    • 注意: 如果卡槽里有 Micro SD 卡的话,在开始下一步之前需要先将它取下来。
    Don't put your SD card on your magnetic mat.
    Chris Cotter - 回复
  7. 更换任天堂Switch背部外壳: 步骤 7 中的图像 1,1
    • 使用 JIS000 螺丝刀(或 iFixit PH000 螺丝刀)拧下位于主机支架下面,一颗 1.6 毫米的螺丝
    • 将支架盖上。
  8. 更换任天堂Switch背部外壳: 步骤 8 中的图像 1,3 更换任天堂Switch背部外壳: 步骤 8 中的图像 2,3 更换任天堂Switch背部外壳: 步骤 8 中的图像 3,3
    • 从设备底部提起后盖并取下
    • 背部盖板连接到塑料外壳的另一半,防止你在关闭后面板时将其完全抬起。
    • 从设备底部向上提起后面板并将其卸下。
    How to remove micro SD port?
    Pull straight up, press back into place when closing back up.
    Christopher Hernandez - 回复
    This step is missing in this guide. Here are the steps from another guide:
    Step 9) 任天堂Switch的右侧Joy Con手柄滑轨的更换
    Step 10) 任天堂Switch的右侧Joy Con手柄滑轨的更换
    David - 回复
    When I lifted up the back cover, it kind of stuck near the headphone port (even with cartridge slot open). But it wasn't a screw or anything and I kind of carefully pulled and wiggled and the cover came off ok
    Doe - 回复
    +1, there is definitely an extra clip there on my day 1 switch
    repofmady -
    I wasn't so careful here and found out during reassembly that I accidentally broke off the clip with the screw hole on the top of the back cover (the clip fell off the device when I turned it over), so I can't put the top screw back in, but oh well at least the back cover is still affixed to the device otherwise
    Justin Johnson -
    Are the little foam pads on the bottom back of the panel needed? They were removed from a panel I have.
    Type1Guy - 回复
    If you're having trouble getting the back cover to fit during reassembly, check to make sure you don't have an SD card inserted in the slot. It will get in the way.
    If you're like me, you might have inserted the SD card to verify your SD reader was working again after doing step 9 reassembly. If so, remove it before proceeding.
    Alex - 回复
结论
将新的替换零件与原始零件进行比较。在安装之前,您可能需要从新零件中转移剩余的组件。
要重新组装设备,请按照逆序进行操作。
请将维修过程产生的电子垃圾带到R2或e-Stewards认证的回收站
维修没有按计划进行吗?尝试一些基本故障排除后的故障排除,或向我们的社区寻求帮助。
82等其他人完成本指南。
由衷感谢以下译者:
en zh
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
Craig Lloyd
于02/10/16注册
38,614 声望
创作了82篇指南
11条评论
Excellent and concise guide.
The new panel doesn’t come with the sticky grille pieces x 2 on the bottom. Is it supposed to be a straight transfer between the old and the new?
fclbriat123 - 回复
You can transfer the grill to the new back plat
Phillip Norton -
Just did this replacement and there are a few things to keep in mind that this review does not mention. There are x2 square foam pieces that can be transferred to the new panel located at the bottom backside of the old. Also, the game cartridge shield hardware and the kickstand holder hardware have to be taken off the back of the old panel and transferred to the new panel. The kickstand has 2 Phillips #000 screws and the game cartridge shield has 1 Phillips #000 screw
Ryan Talbert - 回复
How do you transfer the foam pieces? Use some heat to loosen their adhesive and then remove them and transfer over the new backplate?
John - 回复
Is the casing the same between the HAC model and the HAD model? This guide doesn’t specify
Julian Webb - 回复
I am using iFixit Pro tool kit. What to do if one of the 000 screw’s cap appears to be stripped off? How to extract it if perchance?
Dr.Genuks - 回复
I had trouble removing the outermost screws, I think they’re actually Y00 as opposed to Y00. Not sure if I’m the only one who’s had an easier time with Y000, if they are I’ll update the wiki
Esme Xuan Lim - 回复
I can’t take out the back screws of my switch with y00 ?
V W - 回复
Detailed guides like this are so helpful!
Swapped the backplates in less than 20 minutes with no issues. I recommend that you press on the screw firmly and turn slowly. Do this and check as you turn and you shouldn't strip any screws.
Yakarot Sennin - 回复
I wanted to support ifixit, and was ok with it being over 3x as expensive as Amazon as it's probably better parts ($13 vs $45). But Amazon had next day delivery whereas here standard is 5-10 days and express is 3-5. I really want to support you guys but you've got to be competitive somehow...
Para Celsus - 回复
Are you guys able to provide the “exact” dimension and thread size for each screw. It would make it easier on use non hardware techies
CG89 - 回复
添加评论
浏览统计数据:
过去 24 小时: 26
过去 7 天: 219
过去 30 天: 1,086
总计 107,684
