简介
使用本指南更换小米红米 Note 7 破裂或损坏的屏幕。
如果框架变形,重要的是更换它以确保新屏幕正确安装并且不会因压力不均匀而受到损坏。
在拆卸手机之前,请将电池放电到 25% 以下。 如果不小心刺破电池可能会着火和/或爆炸,但如果放电,发生这种情况的几率会低得多。
注意:本指南指导你只更换屏幕,同时保留原始框架和主板。但是,这款手机的一些更换屏幕预先安装在新框架(也称为机箱)中,这需要一个非常不同的过程。在开始本指南之前,请确保你拥有正确的部件。
重新组装设备时,你需要更换粘合剂来重新连接组件。
你所需要的
如果粘合剂变得难以切割,则它很可能已经冷却。使用 iOpener 或热风枪重新加热。
在手机的左下角下方插入第三个撬片。
将撬片滑到左上角以切断粘合剂。将其保留以防止粘合剂重新密封。
如果可能,请在安装新粘合剂和重新密封之前打开你的设备并测试你的维修情况。
要重新组装你的设备,请按逆序按照这些说明进行操作。用异丙醇 (>90%) 清洁相关区域后,在必要时涂抹新的粘合剂。
固定新屏幕的最佳方法是 在屏幕背面贴上一张定制切割的双面胶带。
将你的电子垃圾送到 R2 或 e-Stewards 认证回收商。
维修没有按计划进行?尝试一些 基本故障排除,或向我们的 [链接|https://www.ifixit.com/Answers|new_window=true|论坛] 寻求帮助。
7等其他人完成本指南。
由衷感谢以下译者:
65%
Yuting Zhao正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
2条评论
This guide is just WRONG and useless.
He disconnect the battery cable and nothing else: if you try this, at step 18 you will just pull a flex cable that is still screwed. The correct ribbon is not the one near the battery connector shown in step 10, but the one on the left under the camera.
Guide shows he removes 3 screews, and these are just to disconnect the battery. After this, it is necessary to remove more screws and actually disconnect the display flex: 1 to free the small metal cover blocking the ribbon (similar to step 9) and 8 more screws on the bottom of the phone to free and remove the loudspeaker, which otherwise will block the display ribbon even if it was disconnected and the first screw I mentioned removed.
Hi A M,
thank you for your feedback. You're completely right. Some prereq guides for the screen guide were set to private and because of that not visible. I made them public and the full display removal procedure should be correct now. If you notice anything else that is wrong or I missed something, please let me know.
