此翻译由机器生成,尚未经过人工审核。 会说这种语言吗? 查看评论。
简介
本指南详细说明塑料齿(Vislon®)拉链常见问题,并明确何种情况可更换拉链头修复,何种情况需整条拉链更换。
准确的问题诊断是Patagonia拉链维修流程的第二步。您可通过致电或在线联系Patagonia客户服务获取原厂替换部件。
Patagonia巴塔哥尼亚拉链维修三阶段
- 识别拉链类型
- 问题诊断
- 线圈拉链问题诊断
- 塑料齿拉链问题诊断
- 实施维修
松弛的拉链头无法有效咬合链齿,导致拉链头拉上后链齿会分开(参见图示#1)。
过度紧压的拉链头会使拉动困难(参见图示#2)。
若出现以上任一情况或拉链头完全缺失,更换塑料齿拉链头可能解决问题。
10等其他人完成本指南。
由衷感谢以下译者:
100%
Monica正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
7指南评论
What if there's no reason other than one side of the slider came off?
Donna Brock - 回复 分享
You can replace just the slider / retrack the one you have!
If the slider is missing, you will need to identify which type of zipper it is (size, is it molded plastic / coil / metal, and what "generation" because some are not compatible with each other). Once you have the right slider, then:
- for a jacket zipper, you take the top stop off the side of the zipper that has the box at the bottom (which is the side the slider lives on). You then put the slider on that side, test it by zipping the jacket up, and then add a new top stop where you took the old one off. You can find these easily online or at a sewing store.
- for a zipper that's sewn in or has a stop over both sides on the bottom, you will open up the bottom of the zipper and guide it onto both sides. You can find tips and tutorials to put a slider onto a zipper on youtube, etc... You'll then need to sew the bottom back together or use a bottom stop to close it. These can be found at a variety of places online and at most sewing stores.
Hope it helps!
Wolveriner:) - 回复 分享
What about if the zipper zips up but the teeth do not keep closed. I.e. zip up the jacket, part of the teeth stay interlocked but from one point on the teeth become undone and do not lock.
Juan Umana - 回复 分享
That's an issue with the zipper slider itself and I have experience fixing it. It's difficult to maneuver the tool because of fabric in the way and it's in a generally awkward spot but possible. Take needle pliers and squeeze down *a little bit* on the back of the zipper slider itself. Doesn't need too much of an adjustment, so squeeze a little and check, and squeeze a little and check. It's the small end of the zipper slider.
