跳转到主内容
Plastic Tooth Zipper Issue Diagnosis
  1. Plastic Tooth Zipper Issue Diagnosis, Zipper parts and terms: 步骤 1 中的图像 1,2 Plastic Tooth Zipper Issue Diagnosis, Zipper parts and terms: 步骤 1 中的图像 2,2
    • Slider
    • Pull
    • Top Stops
    • Box and Pin
    • Teeth
    • Zipper Tape
  2. Plastic Tooth Zipper Issue Diagnosis, ISSUE: Damaged slider: 步骤 2 中的图像 1,2 Plastic Tooth Zipper Issue Diagnosis, ISSUE: Damaged slider: 步骤 2 中的图像 2,2
    • A common issue for a plastic tooth zipper is slider damage:
    • A loose slider won't keep the teeth together effectively and they will split open after the slider has been pulled up (reference image #1).
    • A compacted slider will be too tight and it will be difficult to pull up the slider (reference image #2).
    • If either of these are the case, or if the slider is missing entirely, it's likely that a Plastic Tooth Zipper Slider Replacement will fix the issue.
    • First check that Steps 3 - 5 do not apply to the zipper and then proceed with the slider replacement.
  3. Plastic Tooth Zipper Issue Diagnosis, ISSUE: Missing or damaged teeth: 步骤 3 中的图像 1,2 Plastic Tooth Zipper Issue Diagnosis, ISSUE: Missing or damaged teeth: 步骤 3 中的图像 2,2
    • The zipper in the first photo has missing teeth. The zipper in the second photo has melted teeth. The only way to permanently fix these issues is to replace the entire zipper line.
    • Check out Advanced No-Sew Zipper Repair Techniques for a temporary quick fix.
  4. Plastic Tooth Zipper Issue Diagnosis, ISSUE: Missing zipper box or pin: 步骤 4 中的图像 1,3 Plastic Tooth Zipper Issue Diagnosis, ISSUE: Missing zipper box or pin: 步骤 4 中的图像 2,3 Plastic Tooth Zipper Issue Diagnosis, ISSUE: Missing zipper box or pin: 步骤 4 中的图像 3,3
    • The zipper in the first photo has a damaged zipper box. The zipper in the second photo is missing the zipper box entirely. The zipper in the third photo is missing the zipper pin. The only way to permanently fix these issues is to replace the entire zipper line.
  5. Plastic Tooth Zipper Issue Diagnosis, ISSUE: Torn zipper tape: 步骤 5 中的图像 1,1
    • The zipper in this photo has a torn zipper tape alongside the plastic teeth. The only way to permanently fix this issue is to replace the entire zipper line.
终点
9等其他人完成本指南。
Brittany McCrigler
于03/05/12注册
90,418 声望
创作了142篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,608篇指南
6指南评论
The link in Step 5 for the slider replacement guide is incorrect. It points to a Powerbook HD replacement guide. TG.
tgarrity - 回复
What if there's no reason other than one side of the slider came off?
Donna Brock - 回复
What about if the zipper zips up but the teeth do not keep closed. I.e. zip up the jacket, part of the teeth stay interlocked but from one point on the teeth become undone and do not lock.
Juan Umana - 回复
That's an issue with the zipper slider itself and I have experience fixing it. It's difficult to maneuver the tool because of fabric in the way and it's in a generally awkward spot but possible. Take needle pliers and squeeze down *a little bit* on the back of the zipper slider itself. Doesn't need too much of an adjustment, so squeeze a little and check, and squeeze a little and check. It's the small end of the zipper slider.
Malm -
I have the same problem as Juan Umana: one tooth at the bottom (beginning) of the zipper is broken off, so the teeth won’t mesh properly and the zipper teeth stay apart. Ideas welcome.
Robin Cunningham
Robin Cunningham - 回复
添加评论
浏览统计数据:
过去 24 小时: 28
过去 7 天: 263
过去 30 天: 1,533
总计 48,762
