简介
使用本指南更换华为 P20 Pro 的破碎后玻璃盖。
打开华为P20 Pro将“损坏设备上的防水密封。如果你不更换胶粘剂密封件,你的手机将正常运行 但是会失去防水功能。
重新组装设备时,你需要更换粘合剂来重新粘上配件。
你所需要的
要重新组装你的设备,请按相反的顺序按照这些说明操作。
安装后盖玻璃后,对手机施加强大而稳定的压力,以帮助粘合剂形成良好的粘合功能,例如将其放在一堆厚重的书本下面。
20等其他人完成本指南。
由衷感谢以下译者:
100%
Yuting Zhao正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
7指南评论
Do you suggest any particular kind of adhesive? I always have trouble with these things. Sooner or later, if not immediately, any glass or screen I fit this way always lifts up. The adhesives that come with the parts always seem weak. I try B-7000 glue or/and double sided tape, but still it won’t sit tight.
Hi Smeargle, the options you already tried are also the ones I’d recommend. When applying new double-sided adhesive I’d also suggest slightly heating the glued area and applying some pressure for a few hours (stack of heavy books overnight might do).
