简介
虽然3DS直到3月27号才在美国发布,但早在2月26号,3DS就在日本亮相,我们从这台日版3DS上获取了一些关于3DS的信息,并了解了他如此火爆的原因。立刻加入我们,一起看看任天堂全新硬件内部的样子。
你所需要的
来自太阳升起的地方的那个令人期待已久的小设备——任天堂3DS,它的质感令人非常惊喜
拥有DS家族最新的外观
裸眼3D的上屏(唉
可用于游戏和摄影的双摄(领先于iPhone!)
“圆盘”摇杆
IR接口
金属触点
修改了开始/选择按钮,增加了主页按钮
3D调节滑杆。通过上下滑动来选择3D显示效果的深度。
3DS的上屏幕通过视差效应来显示3D图像。上屏幕LCD中的一层结构可以根据3D调节滑杆的位置让双眼看到略微不同的画面。当从推荐的距离观看时,画面就会产生3D效果。
任天堂并非第一次尝试3D游戏。Virtual Boy曾经用超酷的技术实现类似的3D效果,但当时并未获得较好的评价。
在拆掉喇叭之后,上屏幕LCD组件即可被拆下。
有三根排线连接到这块屏幕上 -- 提供画面信号,控制视差障壁来让3DS游戏产生3D效果。
Nikkei Electronics' Tech-On 的朋友对这块LCD屏幕做了更深入的拆解研究,并找到了六个分离的的光学组件。
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
18条评论
Lack of details : "Removing the remaining pesky screws securing the motherboard to the lower case." (where and how many?)
********Note: If your top or bottom screen was working before disassembly and doesn't work after reassembly, then it's likely that the connector is loose or dirty or damaged or not clipped or PLACED UPSIDE-DOWN. I had this issue with my Super3DS XL(2015 New3DS XL) and it turns out that the reason why my top screen wasn't working after put together, was because I had the top LCD connector upside-down. After I correctly put the connector in, It worked again! :) ********
Thanks for great guide - I could'nt find the access to the screws on the top screen until I read your guide.
Only problem I had was that I rounded out 2 of the screws in Step 9 and had to carefully drill the heads off and remove the shanks later. So I strongly recommend using the correct and good quality screwdriver as these are very tight
********Note: If your top or bottom screen was working before disassembly and doesn't work after reassembly, then it's likely that the connector is loose or dirty or damaged or not clipped or PLACED UPSIDE-DOWN. I had this issue with my Super3DS XL(2015 New3DS XL) and it turns out that the reason why my top screen wasn't working after put together, was because I had the top LCD connector upside-down. After I correctly put the connector in, It worked again! :) *********
Where does that black plastic piece directly above the blue SD card go? I can't seem to find a picture of it in place
