简介
使用本指南更换三星 Galaxy Note20 Ultra 上的电池。
为了你的安全,在拆卸手机之前,请将电池放电至 25% 以下。这可以降低在维修期间电池意外损坏时发生危险热事件的风险。如果你的电池膨胀,采取适当的预防措施。
你所需要的
沿着后盖的三个剩余侧面重复加热和切割粘合剂的过程。
继续操作时,在每个角落留下一个撬片,以防止粘合剂重新密封。
在手机的整个周边来回滑动撬片,以切割任何丢失的粘合剂。重新加热任何顽固的粘合剂。
为了获得最佳性能,请在完成本指南后校准新安装的电池。
将新的替换部件与原始部件进行比较 - 在安装之前,您可能需要转移剩余的组件或去除新部件上的背胶。
要重新组装您的设备,请按照相反的顺序执行这些说明。
将您的电子废物带到 R2 或 e-Stewards 认证回收商。
修复没有按计划进行? 尝试一些基本故障排除,或询问我们的Samsung Galaxy Note20 Ultra 社区寻求帮助。
28等其他人完成本指南。
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
8指南评论
where did you buy the new battery from?
What is the precut adhesive card used for?
Thank you so much!!! My battery was starting to bulge badly. While the life was still satisfactory, the shape of my phone was beginning to become very distorted, the side buttons no longer worked properly in my DBrand case, and when I pressed my finger on the fingerprint sensor, my screen would depress and click. Not only did you offer the battery and tools needed, but a perfect guide to installing it. Simply amazing.
I just wish you would lose the ridiculous communist imagery on your branding. Repairing products is not communist, it just makes sense. Let's make right to repair an American virtue again, and not model the movement off some Maoist revolution.
Just want to note, I bought the precut adhesive, and battery adhesive from this guide, only to start looking around more and find that Ifixit also sells the note 20 ultra 5G precut adhesive so you don't need to deal with putting the precut adhesive strips around the edge.
Fun note, it also comes with the battery adhesive, so now I have an extra battery adhesive, as well as precut tape strips that I probably will never use, or if I do use, will probably never be able to find them... lol
I made this same mistake of ordering an extra battery adhesive when I ordered last month. I guess I just read the title, as the description mentions the battery adhesive.
David M -
