简介
本指南介绍了如何卸下和更换Samsung Galaxy S20 Plus的电池。
使用强力胶将电池固定到位。高浓度(超过90%)的异丙醇将使电池去除过程更加容易。
如果你的电池膨胀,采取适当的预防措施 并且不要加热手机。
为了你的安全,请在拆卸手机前将电池放电至25%以下。如果电池在维修过程中意外损坏,可降低发生危险热事件的风险。
你所需要的
将吸盘套在手机背面,并尽可能靠近左边缘的中心。
用强大的稳定力拉动吸盘,以在后盖和框架之间形成一个间隙。
将三角撬片的尖端插入间隙中。
你也可以尝试在接缝中滴几滴高浓度(超过90%)的异丙醇,以帮助松开粘合剂。
在框架和电池边缘之间的间隙中使用高浓度(超过90%)的异丙醇。
使用酒精时,请倾斜设备,以帮助其渗透电池下方的粘合剂。
涂完酒精后,继续向各个方向倾斜手机两到三分钟,以帮助酒精进一步渗透。
将新的更换零件与原始零件进行比较 - 在安装之前,你可能需要转移剩余的零件或从新零件上取下粘性衬板。
要重组设备,请按逆序执行以下说明。
在完成本指南后,请校准你新安装的电池。
将你的电子垃圾带到R2或e-Stewards认证的回收商。
修理没有按计划进行?查看我们的论坛以获取故障排除帮助。
26等其他人完成本指南。
由衷感谢以下译者:
50%
Yuting Zhao正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
14指南评论
Do you need new adhesive to glue the front and back of the phone itself back together after replacing the battery?
That is insane !!! I am replacing my Note 4 with an S20+. With the Note 4, one just opens the back, lifts the battery out and clicks in the new one. 10 seconds or less. I will NOT be trying to perform this 31 step, 30-60 minute replacement if the battery on my S20 needs replacing. Cheaper to replace the %#*@ phone. WTF were Samsung thinking???
I don't know if the overseas version is different from the Korean model I have (it's probably the same), but I've heard stories from repair shops that the liquid crystal died because they used alcohol to remove the battery. In fact, after the replacement, the liquid crystal was slowly dying and then completely dead the next day. The only thing they said to do to remove the battery was to apply a lot of heat. Other than that, the rest of the steps seem to be fine. I just changed my phone to an S21+ because the liquid crystal was expensive. I signed up to try this. I hope everyone else has no problems replacing it...(it's not hard, except for the back plate and battery removal, which is a pain).
changmin lee - 回复 分享
