简介
使用本指南可拆卸或更换Samsung Galaxy Note10上的屏幕。
由于Note10+的设计,你必须卸下后面板才能断开屏幕电缆的连接。
在开始此过程之前,请确保后面板和屏幕都有一套替代粘合剂。
你所需要的
对手机的其余三个侧面重复前面的加热和切割步骤。
继续进行下一步操作时,请在每侧留一个三角撬片,以防止粘合剂重新密封。
垂直向上提起后面板以将其卸下。
Muy buena la guia. nada que añadir. para montar solo limpia el equipo donde estaba el tape anterior, y remoueve los el tape de la tapa nueva solo ponla y listo…
向上倾斜金属屏蔽罩,以便可以用手指抓住它。
向上剥开无线充电线圈,使其远离设备。
卸下无线充电线圈。
Can you reuse the wireless charging coil? I don’t see a replacement on the site. I just learning all this.
Jon Marble - 回复
将新的替换零件与原始零件进行比较——在安装之前,你可能需要转移剩余的组件或从新零件上取下粘性衬板。
要重新组装设备,请按逆序执行上述步骤。
将你的电子垃圾带到R2或e-Stewards认证回收商。
维修没有按计划进行吗?尝试一些[[修复后的问题|基本故障排除],或向我们的社区寻求帮助。
要重新组装设备,请按逆序执行上述步骤。
24等其他人完成本指南。
由衷感谢以下译者:
96%
Yuting Zhao正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
9条评论
Thanks for the hard work that was put into this so are able to fix our own phones. Very much appreciated!
George Ray - 回复
How do you take the front glass screen off the OLED display/ screen? I couldn't find anything on this site. You would think they would because you can buy just glass screen that goes on the front of the OLED display.
Hi Austin,
Removing the front glass requires slicing through the LOCA (liquid optically clear adhesive), which is pretty tricky to complete and requires specialty tools. The screen glass part by itself is bought primarily by refurbishment/repair shop companies that have the necessary tools to complete that kind of repair.
Hello, does fingerprint sensor and face recognition works after replacing display+frame assembly? New part is original, not OEM.
I have this phone and someone removed the glass and now there is a solid gold flat surface where the screen was is there anything I can do with it?
I knew I could do this, but the guide sure helped. Thank you!
I would search up that kind of guide on YouTube. I've done it before and it's very, very tricky. A few different things can go bad if you don't have the right equipment.
I have an adjustable hot plate. I bought it when I replaced the back and battery on a previous note. I am wondering about some type of shim so that the camera bump is not in contact with the hot plate. I am thinking about fender washers. Is there a better way?
Rusty Lingenfelter - 回复
