跳转到主内容
三星 Gear S2 表圈更换
你所需要的
  1. 三星 Gear S2 表圈更换, 表圈: 步骤 1 中的图像 1,2 三星 Gear S2 表圈更换, 表圈: 步骤 1 中的图像 2,2
    • 将塑料开口工具插入嵌框下方,然后向上撬嵌框。
    Pay attantion to the spring and little ball!
    Eric M. - 回复
    If possible, try to have the watch on a watch pillow while you're working. Be very careful when removing your bezel and work over a towel to make sure none of the tiny parts escape. There will be four white round bearings at approximately the 1, 5, 7, and 11 o'clock positions. If you do end up disturbing them, beneath these bearings will be four tiny springs. If you lose one of them, you're probably screwed, so be very careful with them. The springs themselves are magnetic, and since mine fell out, I had to figure out how to get them back in. A cell phone SIM card removal tool works perfectly to aid in easily getting them back in. The SIM card tool fits inside the spring, so all you have to do is set in in the hole in the face of the watch and use anything non magnetic to slide the spring off of the tool. From there, just set the bearing back in place and tilt the watch very slightly to roll it into the hole and on top of the spring.
    Ed Campbell - 回复
    I required Samsung Gear 2 watch strap holder please message me if you have I would like to order please thank you
    helenvivian1107 - 回复
    Samsung Gear 2 watch strap holder.
    Where can I get repaire kit
    Pawan Kumar - 回复
  2. 三星 Gear S2 表圈更换, 2个易丢部件: 步骤 2 中的图像 1,3 三星 Gear S2 表圈更换, 2个易丢部件: 步骤 2 中的图像 2,3 三星 Gear S2 表圈更换, 2个易丢部件: 步骤 2 中的图像 3,3
    • 撬下嵌框时,确保不要用力过大,否则会丢失重新组装所需的2个部件。在容器中进行此操作以防丢失部件是一种有效的安全措施。
    • 1.金属嵌框
    • 2.塑料护圈
    • 第三张图是卸下部件后的手表。
    Ho smarrito il supporto in plastica…dove posso trovarlo? Grazie
    Massimiliano Morichini - 回复
  3. 三星 Gear S2 表圈更换, 清洁: 步骤 3 中的图像 1,1
    • 可以使用以前用来撬开金属嵌框的工具来清洁金属嵌框。清除任何卡在里面的东西,可以使第5步容易得多。
    Pour some rubbing alcohol into a shallow tray and place the bezel face up in it. This will help with loosening the gunk that has accumulated in all the tiny holes around the back of the bezel. Allow to soak for a few minutes to remove the gunk from the holes. This will give a much more well defined click when rotating the bezel. You can also use the end of the SIM card tool or an old toothbrush to help clean out each hole. Rinse thoroughly and dry before placing the retainer ring in the groove. As far as putting oil on the retainer, I would say it's probably not a good idea. I put everything back together dry, and it works just as well now as it did the day it was new.
    Ed Campbell - 回复
  4. 三星 Gear S2 表圈更换, 继续清洁: 步骤 4 中的图像 1,1
    • 清洁塑料护圈需要比挡板更加小心,因为它特别脆弱。小心地将它夹在两个手指之间,用棉签轻轻地清洁由手指支撑的部位,请确保清洁完全.
  5. 三星 Gear S2 表圈更换, 重新组装: 步骤 5 中的图像 1,2 三星 Gear S2 表圈更换, 重新组装: 步骤 5 中的图像 2,2
    • 护圈表面呈脊状的一面需要朝下。
    • 固定器位于金属嵌框内侧的凹槽中,如图所示。注意图像中护圈的方向。夹持器应在不施加力的情况下固定在嵌框的凹槽中。
  6. 三星 Gear S2 表圈更换, 继续重新组装: 步骤 6 中的图像 1,2 三星 Gear S2 表圈更换, 继续重新组装: 步骤 6 中的图像 2,2
    • 将护圈固定在嵌框中,需要嵌框面朝下放置在手表表面上,首先放置固定器中开口的一侧。如果不这样做,护圈可能无法正确就位,如第一张照片所示。
    • 如果发生这种情况,用手轻轻撬起嵌框和护圈,将护圈重新安装到嵌框中,然后重试。
    • 一旦你成功地更换了手表的表圈,它会像新的一样,可以自由旋转。
    Everything went fine up until this last step. I tried and tried and tried to get the bezel snapped back into place following the directions, but I always ended up unable to get one side of the bezel to press into place. What I ended up doing was placing the split in the ring at the 12 o'clock location, and instead of lining and pressing that section down first, I started 180° away from the split and got that aligned in the six o'clock pisition first, then I started working my way around the watch equally until I got to the split which was at 12 o'clock, I touch the bezel lightly with the tip of my finger and it clicked and fell right into place. The bezel is now in place and functioning exactly as it did when it was new. Aside from this one step, the tutorial went exactly according to plan.
    Ed Campbell - 回复
    Does anyone know where to find a replacement for a s2 classic rosegold bezel? My mom's fell off and she lost it all.
    Adam Orcutt - 回复
    Where can I buy the bezel ring
    thianaven rayapen - 回复
    Where can I buy the bezel ring for my Samsung gear S2SM-R730A watch
结论
你的挡板现在应该可以自由旋转,没有任何阻力。
20等其他人完成本指南。
由衷感谢以下译者:
en zh
100%
Tim Brain正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
Jacob Baldwin
于02/20/17注册
3,412 声望
创作了5篇指南
团队
USF Tampa, Team S2-G3, Sullivan Spring 2017 USF Tampa, Team S2-G3, Sullivan Spring 2017 的会员
USFT-SULLIVAN-S17S2G3
3 名成员
创作了23篇指南
20条评论
This is kind of a sick joke. The bezel has four of the tiniest screws and ball bearings imaginable which are impossible to find-almost better if you don’t, since you will never get them reinstalled!!
Stephen Ouellette - 回复
? There are no screws in the bezel, it is exactly as shown here if you have an S2 non-classic
Kevin Criswell -
I did not have any screws, but there were 4 very small plastic bearings! Thank goodness I did not loose them. Be careful. If they come out a little spit and put them back in the socket they sit in and they will stay. I had to try 4 times to get the ring back in right. My bezel moved well before I started but the watch did not react to it. Now after cleaning things are working better.
Patrick Hall -
Das Ablösen funktioniert. Allerdings gibt es eine winzige Kugel und eine winzige Feder, die dabei sich ebenfalls lösen und wieder an die richtige Stelle müssen. Die Gefahr diese zu verlieren ist gewaltig (mir passiert). Man kann diese unter rounded.com nachbestellen. Es ist aber sehr schwierig, diese wieder an die richtige Stelle zu bekommen. Daher ist die Anleitung Schrott.
Stefanie Endres - 回复
Were I can her the bezel Gera 2
Federico Branca - 回复
Were I can get the gear 2 bezel
I lo ve in
this is also true for gear s2 classic?
Moa cat - 回复
No, S2 sport.
free mail -
I regret not having read the comments first.
I lost four springs.
exjang0 - 回复
Where can you buy the replacement parts for this in the US?
J Andrew W - 回复
My s2 still wont work the springs and beads never came out and I cleaned the bezel, the retainer, and even cleaned the lining on the watch where the bezel attaches, but it still wont work. Any suggestions?
ASMR_tech - 回复
its magnests
Be Tu -
Does anyone know how the watch senses bezel rotation? I have a Gear S2 R-730A which has stopped responding to bezel rotation. I have followed the steps in this guide to pull of the bezel and clean things underneath, but the watch still does not respond. I need to know what may need to be replaced to restore the watch’s ability to respond to bezel rotation. Any ideas?
Brian Doe - 回复
Pay attention on four white plastic balls inside! No photo in this tutorial, why? Use needle on cleaning all holes in the ring. I recommand isopropyl alcohol. But after careful claning the bezel still not works, watches no detect moving with him. Factory reset without result too.
free mail - 回复
After a few restarts and power off, bezel ring works…
free mail - 回复
This is the link I used, I have the SM-R720. Parts came on time, and are working good so far, just replaced, so we’ll see if they hold up https://rounded.com/samsung-galaxy-gear-...
Mike Eubank - 回复
I have lost the bezel, where can I order a replacement bezel? S2 Classic.
Sharon Patterson - 回复
This is bullshit, when you pop off the ring the little balls will pop out and be lost
Eric Vanhoozier - 回复
Will this work for a galaxy s3 frontier because there's times my works but then while I'm spinning it it stops moving the screen
Conradimus18 - 回复
I was working on a car and my watch snagged something that took the ring off completely. I've been searching for a complete bezel to replace it. Does anyone know where to find one?
Troy Rushing - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 37
过去 30 天: 117
总计 37,161
