跳转到主内容
2007 Chevy Aveo Indicator light bulb Replacement
你所需要的
  1. 2007 Chevy Aveo Indicator light bulb Replacement, Indicator light bulb: 步骤 1 中的图像 1,3 2007 Chevy Aveo Indicator light bulb Replacement, Indicator light bulb: 步骤 1 中的图像 2,3 2007 Chevy Aveo Indicator light bulb Replacement, Indicator light bulb: 步骤 1 中的图像 3,3
    • Here is a view of the left tail light assembly
    • Open the rear hatch,( or trunk if it is a sedan). On the inside of the assembly are two retaining screws. Remove those
    • both screws are #6x3/4 inch
  2. 2007 Chevy Aveo Indicator light bulb Replacement: 步骤 2 中的图像 1,3 2007 Chevy Aveo Indicator light bulb Replacement: 步骤 2 中的图像 2,3 2007 Chevy Aveo Indicator light bulb Replacement: 步骤 2 中的图像 3,3
    • Here is a view of the assembly with the screws removed.
    • Insert some sort of prying tool between the tail light assembly and the body, just below the crease in the body and pry to the rear of the vehicle. a snap will be felt/heard as the plastic stud releases
    • Move the prying tool to above 1 1/2 inch above the bottom of the assembly. Insert it between the assembly and body and gently pry toward the rear of the vehicle. This should free the second stud.
  3. 2007 Chevy Aveo Indicator light bulb Replacement: 步骤 3 中的图像 1,3 2007 Chevy Aveo Indicator light bulb Replacement: 步骤 3 中的图像 2,3 2007 Chevy Aveo Indicator light bulb Replacement: 步骤 3 中的图像 3,3
    • Now just pull the assembly straight back.
    • Avoid pulling the assembly to one side or another, that can snap the plastic studs
    • Locate the burned out bulb. In this case it was the indicator light. Rotate the bulb sockets in a counterclockwise direction.
    • Pull the sockets straight out of the tail light assembly.
结论
7等其他人完成本指南。
oldturkey03
于09/29/10注册
784,262 声望
创作了119篇指南
团队
Global Fixers Global Fixers 的会员
Community
33 名成员
创作了558篇指南
2条评论
This was a great help thank you!!
Jeffrey Blum - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 18
过去 30 天: 75
总计 9,702
