跳转到主内容
本文件第一页的预览
请登录以查看完整文档
31 页 · 2.73 mb · PDF
登录
PRO X SUPERLIGHT
SETUP GUIDE | GUIDE D'INSTALLATION
ENGLISH3
FRANÇAIS10
ESPAÑOL17
PORTUGUÊS24
Table Caption: This table lists four languages and assigns a numerical value to each, with Spanish and Portuguese having significantly higher values than English and French.
PACKAGE CONTENTS
  • 1 Mouse
  • 2 Optional grip tape
  • 3 Receiver (installed in extension adapter)
  • 4 USB charging and data cable
  • 5 Surface preparation cloth
  • 6 Optional POWERPLAY aperture door with PTFE foot
MOUSE FEATURES
  • 1 Left Click
  • 2 Right Click
  • 3 Middle Click/Scroll
  • 4 Browser Forward
  • 5 Browser Back
  • 6 Power LED
  • 7 USB charging/data port
  • 8 Power on/off
  • 9 POWERPLAY™ Aperture door
SETUP
  • 1 Plug charging/data cable into PC, then plug extension adapter and receiver into charging/data cable
  • 2 Turn on mouse
  • 3 To configure mouse settings like DPI, download G HUB software from logitechG com/GHUB
For optimal wireless performance, use mouse within 20cm of receiver and greater than 2m from sources of 2.4GHz interference (such as wifi routers).
To install optional grip tape, first clean surface of mouse with provided surface preparation cloth to remove any oil or dust. Then, carefully align grip tape to mouse surfaces.
The USB receiver can be stored inside the mouse by removing the POWERPLAY aperture door. This can prevent the receiver from being lost when using the mouse with the Logitech G POWERPLAY wireless charging system.
Removing this door also allows the included, optional aperture door with PTFE foot to be installed instead of the default aperture door.
CONTENU DU COFFRET
  • 1 Souris
  • 2 Bande antidérapante optionnelle
  • 3 Récepteur (installé dans l'adaptateur d'extension)
  • 4 Câble de charge USB et câble de données
  • 5 Tissu de préparation de la surface
  • 6 Compartiment à ouverture optionnelle POWERPLAY avec patin PTFE
6
CARACTÉRISTIQUES DE LA SOURIS
  • 1 Clic gauche
  • 2 Clic droit
  • 3 Clic central/roulette de défilement
  • 4 Avancer d'une page dans le navigateur
  • 5 Reculer d'une page dans le navigateur
  • 6 Témoin d'alimentation
  • 7 Port USB de charge/données
  • 8 Marche/Arrêt
  • 9 Compartiment d'ouverture POWERPLAY™
INSTALLATION
  • 1 Connectez le câble de charge/données sur le PC, puis l'adaptateur d'extension et le récepteur au câble de charge/données
  • 2 Mettez la souris sous tension
  • 3 Pour configurer les paramètres de la souris, comme sa résolution, téléchargez le logiciel G HUB à l'adresse logitechG com/GHUB
Pour bénéficier de performances optimales en mode sans fil, utilisez la souris dans un rayon de 20 cm autour du récepteur et à plus de 2 m des sources d'interférence à 2,4 GHz (notamment les routeurs Wi-Fi).
Pour installer la bande antidérapante optionnelle, commencez par nettoyer la surface de la souris avec le tissu de préparation de surface pour retirer tout résidu de graisse ou de poussière. Positionnez ensuite soigneusement la bande antidérapante sur les surfaces de la souris.
Le récepteur
