跳转到主内容
Released June 2009 / 2.53 GHz Core 2 Duo Processor
170 个问题 查看全部
Good guide to replacing trackpad?
My dog somehow stepped on my trackpad and cracked it. I've been looking for video guides for replacing the trackpad on this specific computer (mid-2009 unibody 15" Pro) but all I've been able to find is the 13". Is the process similar? Also, what tools do I need to replace the trackpad?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
3个答案
已选择的解决方案
Yes - Spudger, T6 Torx Screwdriver, Phillips #00 Screwdriver,5-Point Torx Plus Pentalobe MacBook Pro Battery Removal Tool.
If this answer was helpful please remember to mark it accepted.
这个答案有帮助吗?
得分 0
添加一条评论
最有帮助的答案
You can disconnect the trackpad from that connector cable, and leave the existing cable in place. That's the easiest way to replace the trackpad, since your cable is still working.
There is a black plastic flap that locks the ribbon cable to the trackpad, that you'll need to flip up with a spudger. The cable is also held to the trackpad with adhesive, you can use a spudger to slowly separate the cable from the trackpad.
这个答案有帮助吗?
得分 1
添加一条评论
Actually, I was trying to follow the "Replacing MacBook Pro 13" Unibody Mid 2009 Trackpad" guide (I own a MacBook Pro 15" Unibody 2.53 GHz Mid 2009, just like in the original post). I followed the guide up to and including Step 5 (removing the battery), but I'm stuck at Step 6. I find that the trackpad connector is somehow inaccessible in the 15" version. Is there a more suitable guide?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Michael Comora 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,496
