跳转到主内容
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 个问题 查看全部
How do I repair a blank but not cracked screen?
I dropped my phone, the screen did pop out but is not cracked. I placed the screen back in. It will ring and works as it should but I can see nothing on the screen still. I hope I have just placed it in wrong.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Hey Crystal,
It sounds like the display assembly was simply not attached correctly. The connector must be installed perfectly, so check out this guide to make sure you attached everything correctly. You might want to consider spraying some compressed air over both parts of the connector to make sure that no dust or dirt gets in the way.
Hope this helps! Good luck!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
crystal 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 710
