跳转到主内容
加入维修社区 - 创建账户
Model A1046 or A1095 / 1280x854 screen resolution
Sold Wrong DC Inboard
Hi, I just purchased a new DC Inboard because mine was loose in the area where the adapter plugs in. The seller sent me the wrong part giving me Part #A1095 instead of part #1046.
After changing a couple of the cables around we were able to get it all connected however it doesn't work. This was my main computer so I know it worked just fine when I was able to charge my battery on a friends computer.
Right now it charges the battery, but just makes a whirring sound like a car does when the battery is low. No chime or anything else.
My question is after I return the board should I try to find the right part or does it sound like something else is now wrong with my baby?
Thank you!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
3个答案
已选择的解决方案
Wait till tomorrow for an answer from Ben Eiseman. He's the best parts man around here.
这个答案有帮助吗?
得分 3
1条评论:
Thanks Mayer for your suggestion. I've put the old board in and it does light up the power plug, the problem is the adapter part is loose, but I will see what happens when I reconnect the logic board.
完成的
添加一条评论
Try and put the old board in, and see if you can get it to boot, if this doesn't fix it, you may have roasted the logic board. These boards put out a specific voltage for the right laptop, and the wrong board could cause some damage.
这个答案有帮助吗?
得分 1
1条评论:
Thank you for your answer. I really have nothing to lose at this point so I'm going to give it a try!
完成的
添加一条评论
The board will work fine in the A1046 and A1095 . I successfully tried it dozens of times.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
N Little 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 17
总计 908
