跳转到主内容
13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
574 个问题 查看全部
Trackpad replacement without keyboard replacement
Can the trackpad be replaced without replacing the keyboard? I have a broken trackpad and can't seem to find a part number for it. My mac is a MacBook Unibody Model A1278.
Thank You
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
6个答案
最有帮助的答案
Yes it can! Your part number is 922-9014. You will, however, need a tri-wing screw driver to replace it. Plugging that part number into Google will lead you to the part.
Good luck!
这个答案有帮助吗?
得分 5
添加一条评论
Thank You for responding my post. I found the part using the part number you provided.
这个答案有帮助吗?
得分 0
1条评论:
Great! I'm glad you found what you needed!
完成的
添加一条评论
I have a late 2008 model Macbook 5,1 aluminum case version. Is this a A-1278? I have a defective trackpad on the unit and need a replacement. Is the part number 922-9014 correct? Thanks, Knut Holzer
这个答案有帮助吗?
得分 0
添加一条评论
Have the same question as above: also have a late 2008 model MacBook 5,1.
这个答案有帮助吗?
得分 0
添加一条评论
Same here. Would love to know.
这个答案有帮助吗?
得分 0
1条评论:
These old questions rarely get looked at. Asking a new question brings better results and new things may have been learned in the last year and half.
完成的
添加一条评论
http://www.everymac.com/ultimate-mac-loo...
Yes, they are all the same machine.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
avelez 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 10,676
