跳转到主内容
Repair information and guides for the CDMA version of the fourth generation iPhone. Model: A1349 / 8, 16, or 32 GB storage capacity
295 个问题 查看全部
Where do I clean if I got finger oil on my parts?
I had my iPhone into a shop for repairing when my power button failed. After I got it back, I have very bad bluetooth reception and almost non-existent WiFi. I remember that the shop did not use gloves. I took it back there and they are denying all responsibility.
So I assume that there's probably some finger oil on various parts and I've seen all of the suggestions on here about cleaning "all contacts" with a degreaser or Windex. But I don't know what "all contacts" are. Can someone help me out and point them out?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
Any help?
完成的
Thanks, Brett. I didn't check this until after I left work so I will try on Monday when I have access to my Pentalobe screwdriver.
完成的
添加一条评论
1个答案
最有帮助的答案
Hey Snowdog,
This is a pretty common problem, and you're correct about the finger oil causing bluetooth to fail.
There are a couple places that you should clean the contacts before re-assembly. While many of connectors in the iPhone use plug-and-socket connections, many just use spring pressure contacts. These pressure contacts are those which you should clean off. Here are a few:
Use some isopropyl alcohol or some Windex on a Q-tip or microfiber cloth, and you should be golden.
Good luck, and let us know how it turns out.
iPhone 4 Power & Lock Button图片
指南
iPhone 4 Power & Lock Button Replacement
难度:
困难
15 - 30 minutes
iPhone 4 Verizon Power Button图片
指南
iPhone 4 Verizon Power Button Replacement
难度:
困难
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
snowdog850 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 2
总计 1,632
