跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2375 个问题 查看全部
Mic not working on calls but working on viber, voxer etc. Ideas?
Hi, whenever I make or receive a phone call, the other person can't heard me at all. I can't heard anything too. (Sometimes all I get is like static noise) The weird part is that whenever I use viber, voxer, heytell or memo voice notes they work great. I already change the dock connector but I got the same error. At this point I don't know if this is a hardware or software problem since the mic and speakers work fine with other applications.
I checked Google for some help but I couldn't find someone with a problem like mine.
Any ideas please, at this point I'm willing to try anything.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
8个答案
已选择的解决方案
Ok I finally find someone who solve this problem. According to him it was the "audio codec" on the logicboard. I don't really know if that's the real name of the chip but that's what he said.
Cost me around $75 and he fix it in 2 hours.
Hope this info let some of you guys with this same problem.
Cheers.
这个答案有帮助吗?
得分 1
添加一条评论
i think the problem is with the noise cancelling microphone located near the headphone jack and the IC chip that controls it, you can bypass this by going into SETTINGS-GENERAL-ACCESABILTY and turning hearing aid mode on. give it a try and see if that helps
这个答案有帮助吗?
得分 0
1条评论:
That didn't help :-(. Any other ideas, I will try anything at this point.
完成的
添加一条评论
Replace the dock connector. It is the bottom microphone that is supposed to work on calls and the top mic works on apps. The issue is definetely with the bottom mic. The mesh on the bottom of the phone may be clogged. I had one come in recently with the same issue. I replaced the mesh in the bottom of the phone because it was clogged completely up. I did not even replace the mic just cleaned it up and replaced the mesh. Make sure the mic is plugged back in the bottom of the phone. Static is an indication of a bad connection. Like my Daddy always told me just because you did it doesn't mean you did it right.
这个答案有帮助吗?
得分 0
1条评论:
Craig, that was already changed "I already change the dock connector" is the statement in the original question.
完成的
添加一条评论
had the same prob, people couldnt hear me, but i can hear them, but when using viber... the mic works just fine- i changed the mic, it worked for 2 days then the prob came back, the guy workin on my iphone said its because of the 'microphone crystal' chip, so we replaced it and it works just fine. am not sure if this is the correct name but the guy showed it to me, it is not included in the microphone, it is a small chip (almost 1mm each side) located in the middle, try to replace it though its a bit hard to find one. it costed me 27 $
这个答案有帮助吗?
得分 0
添加一条评论
I've seen this issue too many times. Very common problem with the iPhone 4. There's a chip that needs to be resoldered.
这个答案有帮助吗?
得分 0
添加一条评论
I had the same problem for about a month until today, May 24, 2013.
I called up my cellular provider and explained the problem to them. They 'refreshed my SIM' and within 6 hours, the problem was solved.
God bless you.
这个答案有帮助吗?
得分 0
添加一条评论
How to resolve the above mentioned issue
STEPS
1. Reset your i-phone (Setting -> General ->Reset ->Reset All Setting)
2. Switch OFF your i-phone
3. Switch ON your i-phone
这个答案有帮助吗?
得分 0
添加一条评论
Hello, i have a problem with my microfone in my laptop, in my calls with skype they can hear me but in viber and in Cisco webex meetings. The laptop is new and i have checked all the settings.
Does anyone know how to guide me to fix it?
Thank you in advance!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Joche 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 25,424
