跳转到主内容
型号A1288,闪存容量:8、16及32GB
451 个问题 查看全部
it turned off, and it only works on power from the wall
I got it to work off battery for a while by hitting the back rather hard, but now that wont get it working, my guess is that something is loose inside. it will work from my wall charger adapter but not my computer. the instant i unplug it it cuts off.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
4个答案
已选择的解决方案
Here's how to replace the battery: iPod Touch 2nd Generation Battery Replacement
Here's the replacement battery: iPod touch (2nd Gen) Battery
这个答案有帮助吗?
得分 1
1条评论:
I have dropped it once but it was in a case, so something might have come loose
完成的
添加一条评论
Well I beat the hell out of it and it works again, but obviously, continuing to do this can't be very good. I have to hit the back to make it work
这个答案有帮助吗?
得分 1
添加一条评论
You're just gonna have to open it up and inspect the connections. You might want to order a replacement battery so when you have it open you can replace the old one if needed. My guess would be a faulty battery as I doubt the connections could get loose inside.
这个答案有帮助吗?
得分 0
添加一条评论
The connections to and from the battery are soldered. Coming loose is a very slim possibility.
这个答案有帮助吗?
得分 0
1条评论:
well they ARE made in china. $*$^ happens to stuff made in china. Like the Toyota brakes. And the lead and the melamine and the exploding tires and the flaming laptop batteries and the radioactive childrens jewelry.
完成的
添加一条评论
添加你的答案
trevor 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 864
