Battery won't charge
I purchased a B & D Dustbuster CHV1410L in May of 2024 and didn't take it out of the box until November 2026. Put it on the charger and charging light didn't go on. Is the battery toast from lack of use?
Could well be; lithium ion batteries generally have a safety feature where they won't charge if their voltage is below a certain threshold, and sitting that long, there's a fair chance the battery has run down far enough to have crossed that line. A replacement battery should get you up and running easily enough, but if you're feeling adventurous you can try to bring the battery back to life.
You'll need to disassemble the battery far enough that you can get to the positive and negative terminals of the battery cell itself, not the connections on the BMS (Battery Management System) - the circuit board on the battery. The idea is to put enough power into the battery cell that it gets it above the minimum charging limit, after which the regular charging system will work again.
I can't tell you anything specific about how to do that on your dustbuster, but the procedure is the same for any Li-Ion battery. I was in the same situation with a tablet dock and ran across this post that got my dock running again.
Acer W510 keyboard dock battery 0% and charging — Acer Community
The TL;DR version is to take a 5V charger, hook up the positive and negative terminals directly to your battery's cell and let it charge for a while. Note that this is NOT a safe procedure; there's a very real possibility of fire or explosion! I did mine on a concrete patio and took refuge behind a concrete retaining wall when I plugged it in. Nothing untoward happened, but you should be aware that it could and take safety precautions.
Should you be brave and/or foolish enough to try this, be sure to take lots of pictures and once you're done you can document what you've done with an iFixit guide to show others how to do it. It's easy, fun, and will earn the appreciation of the repair community, especially those who come after you with the same problem!
Good luck, and whatever you decide, be sure to come back and let us know how it all turns out; what you learn will help the next guy looking for answers.
这个答案有帮助吗?
过去 24 小时: 24
过去 7 天: 24
过去 30 天: 24
总计 24
