跳转到主内容
Repair information and guides for the CDMA version of the fourth generation iPhone. Model: A1349 / 8, 16, or 32 GB storage capacity
295 个问题 查看全部
Wont charge after screen repair
I replaced the touch screen and back panel. The iPhone worked fine before it just had a cracked touch screen. after replacing the broken screen the phone works great however, it wont charge or recognize itunes when plugged into the computer. I have power cycled the phone, opened it up again and made sure all the connections are clean and plugged in properly and it still wont charge. If the phone is off when I plug it in it will turn on but wont show that it is charging. The only thing I can guess (after looking online) that is wrong it a fuse may have blown during the repair. When I removed the batter the first time I did notice a tiny spark by the connection, but I could see no damage and the phone works properly in all aspects except charging.
Any suggestions?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
3个答案
已选择的解决方案
Sparks are never good. Possibly a solder pad lifted between the battery connector leads and the Logic Board. If this is the case it could be a simple solder job, or a very complex procedure with bypass wires needed.
这个答案有帮助吗?
得分 2
添加一条评论
Double check that your dock connector is plugged in all the way. Here is a link to the dock connector guide.
这个答案有帮助吗?
得分 0
添加一条评论
i've got the same problem - replacement screen worked fine after the repair but when the battery ran down it just wouldn't charge. Usual sign when I switch on of low battery and insert charging cable screen, but nothing happens when I insert th cable - have checked the connections and they all seem fine and I was careful when I disconnected the battery.
Very annoying - any tips welcomed....
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Clark 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 4,456
