跳转到主内容
加入维修社区 - 创建账户
有关 Mariner 传统船外机的维修信息与服务支持,这些产品通常与 Mercury Marine 及相关的国际船外机产品线有关。
2 stroke won't start
Why won't my 2 stroke marine motor not start?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Adding to moe_r's reply, a spark test would be removing one or all spark plugs, examining them for fresh raw fuel (wet, smell), then connecting to ignition coil or wire while grounding the plug base to the engine (unpainted parts). Do you see/smell fuel on plugs or not? Try starting and observe for spark on the plug. Is your outboard electronic fuel injection or carburetor? EFI systems can be difficult to diagnose but not insurmountable with background info. EFI can have electronically controlled spark and fuel injectors. Carburetors fall into two types; float or diaphragm operated from crankcase pressure.
由完成的 分享
添加一条评论
1个答案
Main reasons an outboard motor won't start: 1. No fuel; 2. No spark 3. No compression Possibly, if you provide more details, I could be more specific. e.g. How old is the gas? Have you changed the spark plugs recently? Pull start or electric start? How many cylinders? How old is the motor? Whar is the motor's serial number? (usually on a plate or decal on the clamp beneath the powerhead). If you've ever forgotten to put the two-stroke oil in the gas (or, fill the oil reservoir), that can be fatal (check the compression). Does it want to start? Or is there no sign of firing when you try to turn it over?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Robin Kline 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 9
过去 30 天: 43
总计 71
